2001 Dodge Durango Infinity Amp Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99177
Printed Date: May 11, 2024 at 1:53 AM
Topic: 2001 Dodge Durango Infinity Amp Wiring
Posted By: dirtyguido
Subject: 2001 Dodge Durango Infinity Amp Wiring
Date Posted: November 20, 2007 at 12:13 AM
Hey,
I'm looking for a wiring diagram for the infinity system for the 01 Durango. I really need the pinouts at the amp. I'm planning on redoing the entire system and removing the infinity amp. I know the speaker wires to the actual speakers are at the amp.
Also, does anyone know what pin in the central timing module (BCM) is the white grey wire from the steering wheel controls?
Thanks in advance,
George
Posted By: KarTuneMan
Date Posted: November 21, 2007 at 9:23 PM
12V DC Battery(Constant) | Pink | | 1 | 15 Amp | Junction block | Switched Accessory | RED / white | | 18 | 10 Amp | Junction block | Ground | Black | | Power Antenna | NCA | | Illumination | White | | Dimmer | Orange | Protected by fuse no. 9 of 5 amperes in junction block | Steering Wheel Control Wire | Gray/white | BLACK/ light green goes to ground. Violet / YELLOW for PCI busses | Left Front + | Dark green | Line level output | Left Front - | BROWN / red | Line level output | Right Front + | Violet | Line level output | Right Front - | Dk.blue/red | Line level output | Left Rear + | BROWN / yellow | Line level output | Left Rear - | BROWN / lt.blue | Line level output | Right Rear + | Dk.blue/white | Line level output | Right Rear - | Dk.blue/orange | Line level output |
AMPLIFIER OUTPUTS | |
Wire Function | Color | Note | Fuse # | Size | Location | 12V DC Battery | Violet | Amplifier pins C1-1 & C1-2 | 13 | 15 Amp | Junction block | Remote Turn On (input) | Dk.GREEN/ red | Amplifier pin C2-4 | Left Front Mid + | Lt.GREEN/ violet | | Left Front Mid - | Lt.GREEN/ dk.green | | Right Front Mid + | Lt.blue/violet | | Right Front Mid - | Lt.blue/black | | Left Rear Mid + | WHITE/ red | | Left Rear Mid - | WHITE/ black | | Right Rear Mid + | Tan/violet | | Right Rear Mid - | Tan/black | |
AT SPEAKERS | |
Wire Function | Color | Note | Left Front Tweeter + | Lt.GREEN/ violet | | Left Front Tweeter - | Lt.GREEN/ dk.green | | Right Front Mid + | Light blue/red | | Right Front Tweeter + | Lt.blue/red | | Right Front Tweeter - | Lt.blue/black | | Left Rear Tweeter + | WHITE/ red | | Left Rear Tweeter - | WHITE/ black | | Right Rear Tweeter + | Tan/violet | | Right Rear Tweeter - | Tan/black | |
