Hello, I need a wiring diagram for a 2008 Pontiac G5. Thanks.
Diagram of what system? Audio? Security? Door lock and windows? Try to be a tad more specific.
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
Below is for 2007 Pontiac G5
Battery RED (+) AT VEHICLE FUSEBOX
Ignition 1 YELLOW (+) IGNITION SWITCH HARNESS
Accessory 1 BROWN (+) IGNITION SWITCH HARNESS
Starter 1 NO TRADITIONAL STARTER WIRE
Anti-Theft Type PK3+
Anti-Theft Descript TRANSPONDER
Passlock 2 bypass
All Door Trigger DARK BLUE/WHITE(-) AT BCM MODULE IN FRONT OF CENTER CONSOLE ON PASSENGER SIDE PLUG C3 - PIN #A3
LF Latch GRAY/BLACK (-) AT BCM MODULE IN FRONT OF CENTER CONSOLE ON PASSENGER SIDE PLUG C1 - PIN #22
RF Latch TAN/WHITE (-) AT BCM MODULE IN FRONT OF CENTER CONSOLE ON PASSENGER SIDE PLUG C1 - PIN #19
Trunk Trigger ORANGE / BLACK (-) AT BCM MODULE IN FRONT OF CENTER CONSOLE ON PASSENGER SIDE PLUG C1 - PIN #31
Parking Lights BROWN / WHITE (-) AT BCM MODULE IN FRONT OF CENTER CONSOLE ON PASSENGER SIDE PLUG C2 - PIN #5
2004 Chevy/Pontiac Intelligent Start Interface
Brake Lights RED / WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
Power Unlock WHITE (-) AT BCM MODULE IN FRONT OF CENTER CONSOLE ON PASSENGER SIDE USE A 1500 K OHM RESISTOR
Power Lock WHITE (-) AT BCM MODULE IN FRONT OF CENTER CONSOLE ON PASSENGER SIDE PLUG C1 - PIN #6 *SEE DOCUMENTS
Single wire door lock diagram-------------
Thanks for the quick response.
