Print Page | Close Window |
2007 kia sorento wiringPrinted From: the12volt.comForum Name: Vehicle Wiring Information & File Requests Forum Discription: Request Car Alarm, Car Stereo, Cruise Control, Remote Starter, Navigation, Mobile Video, and Other Vehicle Specific Wiring Info, Manuals, Tech Tips URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99279 Printed Date: May 15, 2024 at 7:16 AM Topic: 2007 kia sorento wiring Posted By: breeb1 Subject: 2007 kia sorento wiring Date Posted: November 23, 2007 at 5:15 PM Does anyone have a tech sheet for a 2007 Kia Sorento?
Replies: Posted By: Twelvoltz Date Posted: December 05, 2007 at 8:12 PM Audiovox lists:
#512093: 2007 KIA SORENTO 4DR SUV WITH 3.3L ENGINE AND PREMIUM AUDIO SYSTEM Audio/Mobile Video WIRE COLOR POLARITY LOCATION Battery GREEN (+) CONNECTOR "B" (14 PIN CONNECTOR) Accesory GREEN /ORANGE (+) CONNECTOR "B" (14 PIN CONNECTOR) Ground BLACK (-) CONNECTOR "B" (14 PIN CONNECTOR) Illumination RED / BLUE (+) CONNECTOR "B" (14 PIN CONNECTOR) Dimmer YELLOW (-) CONNECTOR "B" (14 PIN CONNECTOR) LF Speaker (+) TWEETER IS BLUE (+)/ MIDRANGE IS BLACK (+)/ SUB IS YELLOW (+) LF Speaker (-) TWEETER IS BROWN / RED (-)/ MIDRANGE IS WHITE (-)/ SUB IS BLUE (-) RF Speaker (+) TWEETER IS BLUE/ORANGE (+)/ MIDRANGE IS BLACK (+)/ SUB IS BLACK (+) RF Speaker (-) TWEETER IS GREEN/ ORANGE (-)/ MIDRANGE IS BROWN RED (-)/ SUB IS WHITE (-) THE FRONT SUB AND MIDRANGE'S MAY HAVE AN AMPLIFIER BUILT INTO THEM. LR Speaker (+) BLUE LR Speaker (-) GREEN RR Speaker (+) YELLOW RR Speaker (-) BLUE Amp Location IF EQUIPPED, UNDER DRIVERS SEAT Security WIRE COLOR POLARITY LOCATION Battery GREEN (40 AMP) BLUE (30 AMP) (+) AT IGNITION SWITCH PINS 2 & 5 Ignition 1 YELLOW (+) AT IGNITION SWITCH PIN# 6 Starter 1 RED (+) AT IGNITION SWITCH PIN# 1 All Door Trigger BLUE (-) IN DRIVERS A PILLAR OR 22 PIN PLUG ON RIGHT AT BCM PIN# 22 MAY ALSO BE A RED / BLACK IN DRIVERS A PILAR. THERE ARE 3 RED / BLACK WIRES MUST TEST TO OBTAIN THE CORRECT WIRE. TEST WITH DRIVERS DOOR LATCHED. Domelight Super SAME AS ALL DOOR TRIGGER (-) USE RELAY WITH LOW CURRENT DOME LAMP OUTPUTS LF Latch BLUE (-) AT SWITCH IN DOOR JAMB OR PIN# 11 IN LEFT PLUG ON BCM ALL LATCH WIRES ARE IN DRIVERS KICK RF Latch GREEN/ BLACK (-) AT SWITCH IN DOOR JAMB OR PIN# 12 IN LEFT PLUG ON BCM LR Latch BLUE/BLACK (-) AT SWITCH IN DOOR JAMB OR PIN# 24 IN LEFT PLUG ON BCM RR Latch BLUE/BLACK (-) AT SWITCH IN DOOR JAMB OR PIN# 24 IN LEFT PLUG ON BCM Trunk Trigger GREEN (-) DRIVERS KICK Parking Lights YELLOW\BLACK (+) LOWER DRIVERS KICK Low Crr Pk Lights WHITE (-) AT LIGHT SWITCH OR BCM PIN# 4 IN A 16 PIN PLUG (PLUG IN MIDDLE) Convenience WIRE COLOR POLARITY LOCATION Headlights-Lo ORANGE (+) UNDER HOOD AT E/R/J/B Headlights-Hi YELLOW (+) UNDER HOOD AT E/R/J/B Parking Brake RED (-) AT SWITCH BETWEEN SEATS OR IN DRIVERS KICK Trnk Release RED / ORANGE (-) THIS WIRE WILL RELEASE THE GLASS THIS WILL RELEASE THE GLASS ONLY. Remote Start WIRE COLOR POLARITY LOCATION Battery GREEN (40 AMP) BLUE (30 AMP) (+) AT IGNITION SWITCH PINS 2 & 5 Ignition 1 YELLOW (+) AT IGNITION SWITCH PIN# 6 Accessory 1 WHITE (+) AT IGNITION SWITCH PIN# 4 Accessory 2 ORANGE Starter 1 RED (+) AT IGNITION SWITCH PIN# 1 Anti-Theft Type TRANSPONDER IN KEY (NOT ALL SORENTOS WILL HAVE THE TRANSPONDER. IF YOUR VEHICLE DOES THERE WILL BE A RING AROUND KEY WITH A YELLOW AND BLUE WIRE COMING FROM IT Anti-Theft Descript RF ACTVATED Key Sense YELLOW/ORANGE (+) NEXT TO IGNITION SWITCH PLUG OR LEFT PLUG AT BCM PIN# 16 Tachometer WHITE (AC) ECM PIN# 61 (CORNER PIN NEXT TO A BLUE). CAN ALSO BE FOUND IN PASSENGER KICK IN A MIDDLE PLUG AS GREEN/ BLACK Speed Sense GREEN (AC) AT ECM PIN# 52(CLOSER TO MIDDLE OF PLUG BETWEEN A GREEN AND BLACK WIRE) OR ISTRUMENT CLUSTER PIN# 15 INSTRUMENT CLUSTER CONNECTOR IS THE MIDDLE 20 PIN PLUG. OR BROWN WIRE AT BCM PIN# 6 IN LEFT CONNECTOR Parking Lights YELLOW\BLACK (+) LOWER DRIVERS KICK Low Crr. Pk Lights WHITE (-) AT LIGHT SWITCH OR BCM PIN# 4 IN A 16 PIN PLUG (PLUG IN MIDDLE) Brake Lights WHITE (+) AT BRAKE SWITCH OR DRIVERS SILL PLATE Reverse Lights BLUE/BLACK (+) IN PLUG ON PASSENGER SIDE OF CONSOLE ABOUT 4 INCHES ABOVE THE CARPET LINE. WIRE RUNS DOWN THE DRIVERS SILL PLATE. Horn BLUE/BLACK (-) AT CLOCK SPRING CONNECTOR OR 22 PIN CONNECTOR AT BCM PIN #10 RIGHT SIDE CONNECTOR Modules WIRE LOCATION Module 1 BCM IS MOUNTED VERTICALLY WITH THE PLUGS FACING DOWN BEHIND THE HEATER/AC CONTROLS Module 2 I/P/J/B (INSTRUMENT PANEL JUNCTION BOX) LOCATED IN THE DRIVERS SIDE KICK (IT IS THE FUSE BOX) Module 3 ECM (ENGINE CONTROL MODULE) LOCATED UNDERHOOD CLOSER TO FIREWALL ON PASSENGER FENDERWELL Module 4 I/C MODULE (INSTRUMENT CLUSTER MODULE) LOCATED ABOVE THE I/P/J/B Module 5 E/R/J/B (E/R JUNCTION BOX) LOCATED UNDER HOOD (FRONT PASSENGER SIDE) Doorlocks/Windows WIRE COLOR POLARITY LOCATION Door Lock Circuit 3 WIRE NEGATIVE Power Unlock WHITE/ SILVER DOTS (-) DRIVER DOOR HARNESS ABOVE FUSE BOX PowerLock BLUE\LT BLUE (-) DRIVER DOOR HARNESS ABOVE FUSE BOX Driver Mtr Unlock WHITE (REV) IN DRIVERS KICK Driver Mtr Lock RED (REV) IN DRIVERS KICK Pas Mtr Unlock WHITE (REV) IN DRIVERS KICK LF Window Up BLUE (REV) AT DRIVERS DOOR WINDOW SWITCH LF Window Dn GREEN (REV) AT DRIVERS DOOR WINDOW SWITCH RF Window Up ORANGE (REV) DRIVERS KICK RF Window Dn RED (REV) DRIVERS KICK LR Window Up YELLOW (REV) BOTTOM PLUG IN DRIVERS KICK LR Window Dn WHITE (REV) BOTTOM PLUG IN DRIVERS KICK RR Window Up YELLOW (REV) DRIVERS KICK RR Window Dn WHITE (REV) DRIVERS KICK Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation. ------------- Installer, IT support, and FFL. I need less hobbies. |
