avh p6500dvd menu
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=102317
Printed Date: May 11, 2026 at 5:33 AM
Topic: avh p6500dvd menu
Posted By: sc0ota
Subject: avh p6500dvd menu
Date Posted: February 18, 2008 at 3:24 PM
I have a avh-p6500dvd unit and when I put in a dvd it will go through the previews and play through all of the monitors correctly. When it is finished showing the preview short movie trailers it will go tho the main menu. then from there it will only let you press numbers for a title or chapter but will not go. When i press the play or fast forward it will give me the 0/. the circle with a line through it,Meaning you cannot do that. the E-brake wire is hooked up and the vechicle is in park. Not sure where to look from here and could not find any topics on this here. Thanks
Posted By: sc0ota
Date Posted: February 18, 2008 at 5:24 PM
Figured it out. I had to play with the settings to use the different arrows to select the play/fast forward. Thanks
