Separating Video, Power, and Audio Cables
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=11974
Printed Date: May 24, 2024 at 8:46 PM
Topic: Separating Video, Power, and Audio Cables
Posted By: Farwell
Subject: Separating Video, Power, and Audio Cables
Date Posted: April 08, 2003 at 8:44 PM
I did a little searching on here and learned to keep the video cable separate from the power cables. I also need to run some RCA audios... what can I run these next to without creating any noise in video and/or audio. thanks!
Posted By: ldpfeifer
Date Posted: April 08, 2003 at 9:38 PM
You can run your cables and check for interfearnce from power or whatever other wires you have. If your car has power seats, you will want to lay your cables in place and run your monitor before you close the area or ty the wires up. Try the seat or other power items to make sure it will not interfear with the signal. You can always move the cables around until you ty or close the work area. Lyle
Posted By: esmith69
Date Posted: April 08, 2003 at 9:48 PM
In general audio and video cables can be run next to each other with minimal interference. Both of these types of signal cables, however, should not be located near power cables. If you have the time and patience there's nothing that'll work better than trial and error as ldpfeifer suggested above.
Posted By: Farwell
Date Posted: April 08, 2003 at 9:59 PM
Have heated seats ever been a problem with noise? I was going put the dvd player and "hideaway box" of which power and video plug into right under a front heated seat. I'll try it out before I permanently lay the lines. thanks so much
