kenwood dnx 7120 vim and rear camera
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=137121
Printed Date: May 01, 2024 at 5:15 AM
Topic: kenwood dnx 7120 vim and rear camera
Posted By: godd dan it
Subject: kenwood dnx 7120 vim and rear camera
Date Posted: August 18, 2014 at 10:06 PM
I installed a Kenwood DNX 7120 unit. I did the bypass for the video in motion by grounding the light green wire on the harness. It works. I also hooked up a rear view camera. The camera only works when I put the video cable into the A/V input/outputs. It doesnt work when the video cable is connected to the rear camera labeled cable on the unit. I do have the correct reverse wire. I dont understanf why it wont work. Is it because I did the video in motion bypass and the unit thinks the car is moving? So the rear camera wont work?
Thanks.
Posted By: Ween
Date Posted: August 19, 2014 at 6:29 PM
Hi,
Did you check the AV Interface set up menu, page 2. R-CAM Interruption needs to be set to ON. May need to select R-CAM Mirror depending on camera used also.
Mark
