ip camera
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=140835
Printed Date: April 28, 2024 at 8:08 PM
Topic: ip camera
Posted By: modfab2502
Subject: ip camera
Date Posted: February 11, 2016 at 1:06 PM
Hi,
Does someone know how to factory reset DAHUA IP CAMERA IPC-HFW4300E ??
I am not able to find the camera using the tool or the default IP.
Best,
S. Gupta
Posted By: the12volt
Date Posted: February 11, 2016 at 1:16 PM
Hold the reset button for 15 seconds while the unit is powered. ------------- the12volt • Support the12volt.com
Date Posted: February 11, 2016 at 2:07 PM
Hi,
There is no reset button on the camera.
Best,
S. Gupta
Date Posted: February 11, 2016 at 2:08 PM
Look for a small dimple, about the size of the tip of an ink pen, near the power plug. That is the reset button. ------------- the12volt • Support the12volt.com
Date Posted: February 12, 2016 at 8:17 AM
Hi,
I could not find any kind of reset button on this camera.
Best,
S. Gupta.
Date Posted: February 12, 2016 at 9:12 AM
That may have been on the S model I found in a quick Google search. The E model is powered by the Ethernet cable. Try unplugging it for 10 minutes or more, else try contacting Dahua at www.dahuatech.com. ------------- the12volt • Support the12volt.com
Date Posted: February 12, 2016 at 11:26 AM
Hi,
Thank you.
I shut down the complete system and then started the cameras one by one over Ethernet. It worked.
Thank you for your help.
Best,
S. Gupta.
Date Posted: February 12, 2016 at 11:29 AM
Good deal! You're welcome. ------------- the12volt • Support the12volt.com
