2004 F150 - Dual rear view cameras with headunit
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=141455
Printed Date: May 04, 2024 at 6:31 PM
Topic: 2004 F150 - Dual rear view cameras with headunit
Posted By: azaraith
Subject: 2004 F150 - Dual rear view cameras with headunit
Date Posted: June 29, 2016 at 11:32 PM
Hi, I have the following equipment that I need to figure out how to install, as a newby but fairly technically competent user...
  • Headunit: Pioneer AVH-3600BHS
  • Camera 1: Rear View Safety RVS-771
  • Camera 2: Rear View Safety RVS-MV1
  • Switch: Rear View Safety RVS-501N-3
  • 12m 5-pin cable (RVS camera 1 to switch) installed
  • 12m 5-pin cable + 12m extension (RVS Camera 2 to switch)
  • Wire to tail light for trigger (installed)
The RVS-501N-3 switch has 3 wires, one for each camera, as well as one wire for ground, one wire for power, and one wire for the trigger. I know the trigger goes to the headunit and the power goes to a power source (cigarette lighter wiring) and the ground to a ground wire (??).
What I don't know is what to do with each of the wires labeled for each camera. I assume they are trigger wires and need to be connected to some switch, but I don't know what... The headunit obviously doesn't have that functionality, so I need to find a way to fab a switch of sorts. They're a single wire, not paired wires, so I have no way to create a circuit... I don't know what kind of switch I'd need to buy, I was thinking some sort of momentary or toggle switch, but couldn't make heads or tails of how to wire it... I'd think a selector switch with options for 1, 2, or 3 would be ideal and I could find somewhere close to mount it, but I need to know what switch to buy and how to wire it.
Does anyone have any input on how to do this project? I've also attached a drawing I've done of the rough way the wires are set up...
Thanks!posted_image
Posted By: azaraith
Date Posted: June 29, 2016 at 11:33 PM
Truck is a crew cab 2004 Ford F150, if that is necessary...
Posted By: azaraith
Date Posted: June 29, 2016 at 11:44 PM
4 position (off + 1 2 3) switch that I think might work?
https://www./itm/660V-20A-6-Terminals-4-Positions-Rotary-Cam-Changeover-Switch-New/351564685494?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20131003132420%26meid%3D1890cfd0e28e4b128bb5f95996ca499e%26pid%3D100005%26rk%3D2%26rkt%3D6%26sd%3D181992230955
Posted By: azaraith
Date Posted: June 29, 2016 at 11:46 PM
Corrected link...
Please ignore the above link atrocity... I didn't know it'd get truncated and unusable (and can't edit)...
Posted By: azaraith
Date Posted: June 29, 2016 at 11:48 PM
Ug... Sorry again, someone delete those? Ebay link won't work, try searching this? "660V 20A 6 Terminals 4 Positions Rotary Cam Changeover Switch"
