Do I Need to Install a Fuse for a Dash Cam?
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=146301
Printed Date: May 09, 2024 at 10:21 PM
Topic: Do I Need to Install a Fuse for a Dash Cam?
Posted By: radkonn
Subject: Do I Need to Install a Fuse for a Dash Cam?
Date Posted: June 27, 2020 at 5:23 PM
I'm trying to hardwire a dash cam. It is a 3 wire hardwire kit (12v constant, ignition, and ground). I noticed a lot of people use fuse taps for these. I was just planning on soldering into the ignition and constant wire at the ignition switch. Should I add inline fuses?
There isn't a fuse box under the dash, so my other option is to run the wires to the fuse panel under the hood and tap in there.
Posted By: i am an idiot
Date Posted: June 28, 2020 at 12:15 PM
The wires on a dash camera are very small. The wires you are connecting to are fused at 10 to 50 amps. The dash cam wires are designed to carry 3 amps. So if you like the vehicle and or the passengers you transport in said vehicle, yes you need to install fuses on both the Constant and ignition wires. No larger than 3 amps.
