Alpine LCD Screen Wiring
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=1743
Printed Date: June 11, 2024 at 11:19 PM
Topic: Alpine LCD Screen Wiring
Posted By: civic545
Subject: Alpine LCD Screen Wiring
Date Posted: July 06, 2002 at 4:59 PM
I got a alpine tme-m750. Why do i have to wire it to the parking brakes, and foot brake? Wut does that have to do with supplying power to the tv? Does my stereo harness have those specific wires for easier wiring or do i have to find the actual wires. EDIT: found out the answer
Posted By: civic545
Date Posted: July 06, 2002 at 8:36 PM
I know this has been on the forum before, but could you please review it again for me? How do i bypass the footbrake and parking brake? This is going on a 97 honda civic ex. Please describe in detail. Thanks! PS: i dont know anything about relays. Read basics/relay, but im still pretty confused as of how to use them.
Posted By: Velocity Motors
Date Posted: July 06, 2002 at 10:37 PM
You need the parking brake and the foot brake because this is Alpine's way out of law suits from consumers who crash their cars because they were driving their cars while watching a movie with their equipment installed. Here are some links for the past posts regarding this topic: ------------- Jeff
Posted By: civic545
Date Posted: July 06, 2002 at 10:52 PM
ok thanks, you say connect the parking brake to ground plus a switch to toggle on/off. So does that mean when the switch is off it is connected to ground and when it is on it has no connection to anything wut so ever? Also, how should i connect the foot brake, i did not see that in the post. Do i ground that wire also? And last, wut wire in a civic gives 12 volts when ignition is turned on? I think i might connect it to the power supply of my stereo but you say i have to connect a relay? Please describe what kind of relay and how i should connect it. Im pretty new to relay business. Sorry alot of questions.
Posted By: Carbotix
Date Posted: July 07, 2002 at 12:07 AM
You take the parking brake wire and ground it. You don't need a switch unless you really want one, just use self control and don't watch TV while you drive. Also get yourself a 12volt light tester @ radio shack. The rest is a no brainer.
Posted By: civic545
Date Posted: July 07, 2002 at 12:19 AM
Wut about the foot brake? There are two wire i have to connect for alpine, parking brake and foot brake. I have 12 volt tester, but i rather have sumone tell me the wire then going through the trouble of testing a few wires just cuz im lazy : P One main question though is how do i connect a relay to the stereo power wire to prevent overloading? Is the relay really nessacary?
Posted By: Carbotix
Date Posted: July 07, 2002 at 1:16 AM
I don't know why there would be a wire for the foot brake but if there is.. there sould be a relay trigger towards the top of your foot brake shaft that you could connect to. Are you sure it's not for a back up camera? If so you don't need it unless you are using one. Answer to question on the relay. I don't use relays for head units. The wiring harness that comes with the head unit sould have an in-line fuse on it to protect you from such things. Hope this helps.
Date Posted: July 07, 2002 at 8:34 AM
Here's the deal with Alpine: You need the foot brake ( which is a (+) input to the TME-M750 ) and the hand brake ( - ) input to the TME-M750 to operate the system while in park. Alpine deviced a system where you need to pull up the hand brake ( which gives the system a (-) signal ) , press the foot brake for a second ( which gives the system a (+) signal ) and then you have to release the hand brake and re-engage it again but this time the (-) signal has to be there for the entire time you wish to enjoy the video portion of your system. Once the (-) signal is removed ( or the parking brake is lowered ) then the system shuts off because it knows that you are in motion once the (-) signal is not present anymore. This is where the toggle switch somes into play. The toggle switch will not replicate the hand brake portion of the sequence. Do the same steps as above, now use the toggle switch ON/OFF to give the system a ground and now as long as the toggle switch is ON ( or GROUNDED ) then the video plays on the screen while you are parked ( ?? ) Hook up the foot brake wire as per instructions as you do not need to place any relays for this connection. The only thing is that once the 12 volt ignition wire is no longer powered( like when you turn off your car or your battery dies ) , you need to re-do the initialization process for the video to play on the screen again. ------------- Jeff
Posted By: civic545
Date Posted: July 07, 2002 at 9:39 AM
foot brake is the GREEN / WHITE wire for a civic correct? Is there anyway i could connect the lcd wire to the wire from my alarm that connects to the brake wire? This would make it much simpler since my brake wire is the hardest wire to reach and manipulate. Also, can you explain to me how i would connect my lcd to the stereo power wire with a relay? You said this would prevent it from overloading or sumthing right? I have no idea how to use relays. Thankyou for your help.
Date Posted: July 07, 2002 at 11:26 AM
Yes, the GREEN / WHITE is the foot brake input wire. Yes, if you have to piggyback another connection on the brake wire, then do so. Get a 30/40 amp 5 pin relay and wire it like so: - 85 : Remote wire from stereo
- 87 : Constant 12 volts
- 86 : GROUND
- 30 : To remote wire on monitor
- 87a: NOT USED
------------- Jeff
Posted By: Carbotix
Date Posted: July 07, 2002 at 4:48 PM
Velocity Motor, Just for my info...... The foot brake is just a positive jump start for the system? Could you for example.. directly ground the hand brake and install a push button switch wich only alows the 12volts to pass through while depressed? Would this work??
Date Posted: July 07, 2002 at 5:40 PM
Yes, this will work as well. I usually don't put this into systems ( the push button for the foot brake ) because it's only necessary at start up of the car and it extra work to install. If you want to you can install the push button if you think it will be easier. Just make sure that you fuse this 12 volt source just in case. ------------- Jeff
Posted By: Carbotix
Date Posted: July 07, 2002 at 6:02 PM
That's good info, Thanks!!!!!!!!
Posted By: mike simonelli
Date Posted: July 14, 2002 at 2:52 PM
Heres another way to do it. can the foot brake you dont need it. On the plug you should have one empty slot take a piece of wire and strip it back like a half inch and push it in the empty slot in the plug after that ground it and wire tie or tape it one inch from where you put it in the plug so it doesnt come out or if you want to pull a wire out of the plug you arent using clip and all and just push it in the empty slot which ever way is easier.This is how we wire the monitors on a display in my store.
Posted By: civic545
Date Posted: July 18, 2002 at 3:41 PM
i just finished installing the screen, finally had the time to do it. Thank you velocity. The install went perfect, easier then i thought it would be. I think i did sum very creative shizz for my first lcd install I made a custom flip out screen with my alpine monitor. Here are sum pictures. I still need to make a faceplate and and a few other visual mods.
Posted By: civic545
Date Posted: July 18, 2002 at 8:45 PM
gotta new question. Is there a way i could wire my ps2 to my kenwood excelon headunit so i can control bass/volume? My headunit has rca type connectors coming out of it. Theres one white and one red rca for the front speakers, and one white and one red for the rear speakers. I tried connecting the one red and one white rca from my ps2 to 2 of the wires coming out of the headunit, but i cant get the headunit to fully play the sound coming out of the playstation. My headunit only give me the option of cd/tuner/alloff. When i turn it on to tuner i can hear a little sound from the playstation, but i cant control volume. How could i connect sound from my ps2 to my stereo?
Date Posted: July 19, 2002 at 12:25 AM
You need to get an FM modulator so that the Play Station will play through the FM band of the radio. UNLESS, the Kenwood has audio INPUTS in the rear of the deck that will support an audio signal going into the deck. The RCA's that you described are OUTPUTS and only put out a signal. You can pick up an FM modulator for about $ 35.00 or less. BTW: That install you made.... is it motorized or just a manual pull out ?? It looks good !! ------------- Jeff
Posted By: civic545
Date Posted: July 19, 2002 at 9:43 AM
As of the moment it is manuel, but later when i have more time i will be able to make a few more mods and add a motor. My kenwood has a input for a cd changer, do they make adapters for that?
Posted By: bigpun
Date Posted: July 28, 2002 at 3:50 PM
you guys playing with the alpine lcds should check out a company called pacific audio. I think their site si www.pacificaudio.com. They have chips available to wire the brake setup that allows you to utilize all features of the decks, without being in park ------------- visit pettyperformance.com
Posted By: CJ Majesty
Date Posted: November 19, 2002 at 2:58 PM
Call alpine & tell them that you have a Truck & that your going to put that TV into a headrest & the have a headrest kit that they can sell you or at least the have it for the tme-m760. That doesnt go through the breaks. I called them today. Because I have racked my brain for the past 24 hours once i found out that you have to go through the brake wires. Now im at ease, after searchin all day how do you think i found this old @$$ thread but just for future reference. That kit by passes the requirement to hook it up to brake wires.
Posted By: Aznpanther98
Date Posted: November 20, 2002 at 2:13 AM
civic how u make that so u can flip out the screen or they make something like that? thats really tight and u can probally if u haven't thought of it to put a door so it can't be seen by potential theives but anyways i'd really like to know how u did that i wanna do that when i get a screen into my car
