dvd and lcd install
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=20464
Printed Date: May 17, 2024 at 7:51 PM
Topic: dvd and lcd install
Posted By: wastedteenyears
Subject: dvd and lcd install
Date Posted: October 23, 2003 at 8:08 AM
i ama nwebie to all this and this is my first attempt to installing this stuff, i was wondering where the best place to hard wire and lcd sreen. i was thinking i coud wire it to the rem wire neaar my head unit, or myabe to the Switched 12V of the head unit. which place would be the best or are nether those 2 an option?
Posted By: Velocity Motors
Date Posted: October 26, 2003 at 7:43 AM
Either one would suffice. Go to the one that is the easierst to get at. You can also use any switched 12 volts power from the fuse box or the ignition harness as well.
------------- Jeff
Posted By: MEATHOUSE
Date Posted: October 30, 2003 at 12:05 PM
If i put it to my ignition wire, won't that vary between 14 and 12 volts?? is this ok for the screen to go through? Do I need a DC-DC converter to keep a constant 12V's or is the cars battery close enough? Thanks, Justin ------------- 2002 Black Corvette Convertible
Posted By: ntredz24
Date Posted: November 17, 2003 at 8:15 PM
no u won't need anything because u will need to use a relay.... so one wire is going to the the 12 pos. when the car is on... ones going to be a 12 always ones gonna be a ground.....and ones gonna go to the device power i wouldn't suggest wiring it right up to the ignition wire.... im kinda new at this too so..... but i think thats the way to do it
Posted By: 1kewlexpo
Date Posted: November 21, 2003 at 2:02 AM
You do not need a relay. If your LCD has 12v and a negative for wires then I would use the Switched 12volts from your head unit. This power source normally has less interference than most of the other Switched 12 volts. Never connect to direct 12volts. You might forget to turn off the unit and can cause a fire. Also, make sure that you have a fuse between the lines. John
Posted By: avxtech
Date Posted: November 21, 2003 at 1:26 PM
John, very good, the fuse box is the NOISIEST place inside the car to get power for MV. The radio is the best place. Make sure you also ground the LCD's and DVD at the same point.
