Hi I just bought a 04 Chevy Suburban with the factory bose 6disk and xm radio,the truck doesnt have the DVD player and i want to install one.
so here is the question-how can i wire the dvd so i can use the factory CD/AUX button on the radio to switch between the aftermarket DVD and the factory stereo system and have the dvd sound thru the factory bose system.
any help would be great!
If there is not a set of aux inputs on the back of the head unit then you could go with an FM modulator.
Jason
periphel makes an aux adapter that gives you the capablity of using the aux button instead of using an fm mod. You get a better, cleaner signal.
well,i have it installed but i'm having a problem with the dome light trigger-after i connected it to the factory trigger when the dome lamps in the truck are on the one on the dvd are out-when i shut the door, the dome lamps go out and the ones on the dvd come on?
any help would be apreciated!
STEVEWCJ wrote:
well,i have it installed but i'm having a problem with the dome light trigger-after i connected it to the factory trigger when the dome lamps in the truck are on the one on the dvd are out-when i shut the door, the dome lamps go out and the ones on the dvd come on? any help would be apreciated!
Is it me? I'm not getting this...
He is talking about the dome light built into the flip down. When the door is open the light is off and when the door is closed the light is on. It is because the car's light use a + turn on and not a - like what the dvd player needs.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
