navigation in 96 accord
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46411
Printed Date: May 23, 2024 at 5:47 PM
Topic: navigation in 96 accord
Posted By: mazdasquash1
Subject: navigation in 96 accord
Date Posted: December 30, 2004 at 6:31 PM
i'm fairley new at this how do u hook up the reverse light circuit and were is it located thanks
Posted By: auex
Date Posted: December 30, 2004 at 8:16 PM
Well, in a honda it is probably running down the driver's kickpanel. As for the wire color, don't know it and can't find it. If you go to the trunk and look at the wires going into the brake light assembly, you can find the color. Just test for the wire that shows +12V in reverse, and ground at all other times. That will be the color and then just look for the same color in the driver's kickpanel.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: December 30, 2004 at 8:24 PM
thanks alot man
Posted By: auex
Date Posted: December 30, 2004 at 9:29 PM
Found it
Reverse Light GREEN/ black + driver kick, harness to rear
