Wish to have DVD system on when key out
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46543
Printed Date: June 05, 2024 at 12:32 PM
Topic: Wish to have DVD system on when key out
Posted By: almora
Subject: Wish to have DVD system on when key out
Date Posted: January 01, 2005 at 2:45 AM
I have a 2000 Land Rover Discovery 2 ,I'm trying to connect my DVD system so that it does not turn off with the ignition off. It is currently wired to a cigarette lighter socket in the back. I would like to keep it as lighter socket powered but how do I bypass the socket to stay on without key in ignition. Much appreciated help ,guidance prethanks guys.
Posted By: dannydoo
Date Posted: January 01, 2005 at 5:03 AM
jump a wire from the fuse box where it says lighter,to a constant power ,ex:horn,acesory lights,headlights,etc.
if you use a test light you will see which fuses have power when theres no key.or you could run a direct line from the battery to the cigg lighter ,must put inline fuse if u do that.
be carefull not to use a small fuse.it wiill pop.
simply pull the chip fuse out and place the wire in the hole.thats one way<not proffesional> but effective and pretty safe...or get some other ideas from evryone else?
Posted By: almora
Date Posted: January 03, 2005 at 2:21 AM
Thanks dannydoo I will try it .
------------- Al
Posted By: slammedb5
Date Posted: January 05, 2005 at 6:37 AM
Use a fuse tap. BTW, your car turns off accessories while the engine is off/cranking for a reason. I wouldn't fool around with it.
