’05 Caravan DVD Options?
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=55030
Printed Date: May 15, 2024 at 10:58 AM
Topic: ’05 Caravan DVD Options?
Posted By: Scrapinsi
Subject: ’05 Caravan DVD Options?
Date Posted: May 03, 2005 at 9:34 AM
A friend of mine just purchased an '05 Grand Caravan SXT. It does not have the overhead DVD or DVD Changer, but he wants to add it. What are his options? Is there an OEM Style that he can put in the overhead console and have it fit and match like factory? I know Pioneer makes the CD Changer cable, but I didn't see anything about OEM integration for mobile video on their website.
Posted By: Ravendarat
Date Posted: May 03, 2005 at 10:28 AM
There are the factory ones that obviously will match up but will cost you an arm and a leg. You can buy aftermarket ones and dye them to match the head liner, you can buy headrest ones from companies like myron Davis where they come in headrests that are matched using the factory cloth that would just drop right in. I mean there are a ton of options out there you just need to look around a little. As far as a overhead that will drop right into the overhead console, you are probally gonna be going back to the factory for that.
Date Posted: May 03, 2005 at 10:32 AM
what about an in dash cd/dvd changer that will work similar to the OEM Setup? Is there an aftermarket option that will work?
Posted By: mobileworks
Date Posted: May 04, 2005 at 9:12 PM
I don't know of any indash dvd monitors that have a built in changer.  If I remember correctly your changer is low on the dash bezel and no aftermarket unit will fit right in its original slot without modification and customization.
However you could still get the ol' big 6 or 10 or 12 disc changer to go with your monitor, however it would more than likely end up in the back of the van do to size...
