06 CRV VSS wire
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=79933
Printed Date: May 29, 2024 at 2:54 AM
Topic: 06 CRV VSS wire
Posted By: wiretapper
Subject: 06 CRV VSS wire
Date Posted: July 04, 2006 at 9:41 PM
Anyone have the color/location for the speed sense wire on an '06 CRV?
Posted By: spookiestylez
Date Posted: July 04, 2006 at 10:12 PM
12volts | white (50A) | + | ignition harness | Ignition | BLACK / YELLOW | + | ignition harness | Parking Lights+ | RED / black | + | back of fuse box, top middle | Notes: Can also use RED / yellow (+) at the front of the fuse box, 18 pin plug, pin 15. | Parking Lights- | blue | - | switch or factory alarm plug | Notes: The factory alarm plug is a green plug to the left of the steering column. | Headlight | blue/red | - | switch or factory alarm plug | Notes: The factory alarm plug is a green plug to the left of the steering column. | Trunk/Hatch Release | BLACK / YELLOW | - | driver kick, door harness | Power Sliding Door | N/A | | | Speed Sense | WHITE/ green or blue/white | | ECM/PCM, pin A18 or E26 | Notes: The ECM/PCM is behind the glovebox. Connector A is a gray 31 pin plug. Connector E is a white 31 pin plug. | Wipers | blue (L), blue / YELLOW (H) | - | windshield wiper switch | LF Window up/dn | RED / black - RED / yellow | A | driver window switch in door | RF Window up/dn | blue/red - blue/white | A | driver kick, door harness | LR Window up/dn | blue/black - brown | A | driver kick, door harness | RR Window up/dn | blue/orange - blue / YELLOW | A | driver kick, door harness | Sun Roof open/close | GREEN/ YELLOW - GREEN/ black | A | moonroof relays above driver kick | Sun Roof Limit/close | N/A | | | Memory Seat 1 | N/A | | | Memory Seat 2 | N/A | | | Memory Seat 3 | N/A | | | Interface Module: | Category: Immobilizer Bypass | Required: Yes | Type: Transponder | Part #: 556HW | Alternate Part1 #: 556UW | Alternate Part2 #: DesignTech 20402 | Alternate Part3 #: DesignTech 29402 | Notes: Standard on all models. |
------------- RTFM
Date Posted: July 04, 2006 at 10:20 PM
Thanks! Exactly what I needed.
Date Posted: July 15, 2006 at 10:58 PM
not a problem, good luck
------------- RTFM
