| One Channel to Multiple Outputs |
You can add multiple functions to an AUX output of an alarm or keyless entry by adding a relay in series with the output wire as shown to any switch or accessory with an output. Only one output can be active at anytime, the one first in the chain (bottom relay in diagram) will have priority, so if you wanted to have the ignition from the key to have priority over the ignition from the remote start, you would connect it to the first relay and the output of the remote start to the next and so on. Also pay attention to the top relay shown. Terminal #87a (the default output) will be active only when none of the coils of the relays are energized. There are many other accessories that can be used with this, including the remote turn on wire and/or power antenna wire of your head unit.
