CM5200 Issue
golfita
Posted: December 25, 2015 at 5:31 PM / IP Logged Link to Post Post Reply Quote golfita
Hey guys,
I have an '02 Corolla with an CM5200 in it.
This morning the remote start didn't start the care, just crancked it and because of the cold and not plugging the car in over night it didn't start. I started it with the key and after I came back home when I locked the car with the remote I saw that the lights didn't blinked but the doors locked. tried to start it from remote but nothing happened. So it locks/unlocks but lights don't come on anymore and it does not start the car, not even crancking. Checked the 2 fuses under the dash on the wiring and they are good. Any ideas?
Thank you!
Platinum - Posts: 7,827
Posted: December 25, 2015 at 7:17 PM / IP Logged Link to Post Post Reply Quote kreg357
Yes, you are in Valet Mode.  The locks working but the Parking Lights not confirming is the give-away.  If you have the 4 button remotes, press Lock and Start at the same time while the ignition is ON.
golfita
Posted: December 25, 2015 at 9:42 PM / IP Logged Link to Post Post Reply Quote golfita
Thanks man! Worked! Only thing is that I had to press lock+trunk to get out of valet mode. Thanks again!!!
Posted: December 26, 2015 at 4:28 AM / IP Logged Link to Post Post Reply Quote kreg357
Could be.  The manual actually says buttons 1 and 3 so I guess it depends on the style of remote.
At least you're all set for the cold weather.   CM5200 Issue -- posted image.
Friday, December 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
