1 ohm amp
neontuner9
Member - Posts: 24
Posted: April 09, 2008 at 2:12 PM / IP Logged
that i do understand but before no one was mention anything about amp ratings just last few post were they mentioned n that i do know that 4 ohm 600w rms is same as 1ohm 600w rms puttin same watts either way thats not wat i was aruging some people just need chill sometimes gettin all hype
the12volt
Administrator - Posts: 3,955
Posted: April 09, 2008 at 2:44 PM / IP Logged
neontuner9, please attempt to use punctuation. It would make your posts much easier to understand. Thanks in advance.
1 ohm amp - Page 4 - Last Post -- posted image. the12volt • Support the12volt.com
willdkartunes
Copper - Posts: 250
Posted: April 09, 2008 at 9:18 PM / IP Logged
I'm as chill as it gets, but you still need to SERIOUSLY listen to haemphyst and the others because they are 100% correct. I run subs all the time for daily listening no lower than 4 ohms and I'm sure most of the systems I've had could bang harder than you could fathom.
Ever sit in a car with the bass hittin and you could hardly breath?.... oh yeah, those subs are running at 4 ohms...
Do whatever makes you happy in life without diminishing the happiness of others
KarTuneMan
Platinum - Posts: 7,056
Posted: April 10, 2008 at 12:25 AM / IP Logged
theetimurban wrote:
Sorry 'bout the double post, but I was just thinkin that since you have a 2 ohm DVC sub, then you could just wire it at 4 ohms, in which case you could get this amp: http://www.cadencestore.com/ProductCart/pc/viewPrd.asp?idcategory=125&idproduct=382
or this one: http://www.crutchfield.com/App/Product/Item/Main.aspx?search=profile+ap1200&i=489AP1200
The Alpine PDX mono amps give max output @ 2 or 4 ohms.  4 ohm from a DVC 2ohm. DONE!
KarTuneMan
Posted: April 10, 2008 at 12:32 AM / IP Logged
neontuner9
You are getting some real good education here.... and it's not costing you a dime.  Learn.
neontuner9
Member - Posts: 24
Posted: April 10, 2008 at 4:38 PM / IP Logged
doodie i just got my education pretty good and hadda pay 10k to go to ii
but thanks dudes wait so 1 ohm isnt good for everyday base?
haemphyst
Platinum - Posts: 5,054
Posted: April 10, 2008 at 4:51 PM / IP Logged
This is what we've been trying to tell you. You have one woofer, dual 2 ohm voice coils. An amp to drive it with 600 watts into 4 ohms will likely be cheaper than an amp to drive it wired for 1 ohm AND you'll have more choices, too...
The amp will run cooler, cleaner, and last longer. Now, knowing that, do you STILL want to spend just 200 bucks?
neontuner9
Member - Posts: 24
Posted: April 10, 2008 at 6:01 PM / IP Logged
this guy recommend this candence amp i have never heard anything about them have you?
DYohn
Moderator - Posts: 10,741
Posted: April 10, 2008 at 10:39 PM / IP Logged
I think that's enough.
Page of 4
Friday, March 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
