2008 hyundai tiburon gs rs/alarm
Welcome Guest :)
jared.malcolm
Member -
Posted: September 14, 2008 at 3:47 PM / IP Logged
Hey just wondering if anyone has the diagram for an 08 Tiburon including trunk/dome and any other convenience options.
Thanks,
Jared
kola7126
Copper -
Posted: September 16, 2008 at 3:17 PM / IP Logged
MODEL | YEAR(S) |
TIBURON | 2004 -2007 |
KEY | T-HARNESS | IMMOBILIZER |
N/A | N/A | HYUNDAI'S TRANSPONDER ANTI-THEFT SYSTEM, Requires 791 Bypass Module and Extra Programmed Ignition Key |
PART | COLOR | LOCATION |
12 VOLT CONSTANT | RED (+) | IGNITION SWITCH HARNESS |
STARTER | WHITE (+) | IGNITION SWITCH HARNESS |
STARTER 2 | N/A | |
IGNITION 1 | RED (+) | IGNITION SWITCH HARNESS |
IGNITION 2 | N/A | |
IGNITION 3 | N/A | |
ACCESSORY /HEATER BLOWER 1 | PINK (+) | IGNITION SWITCH HARNESS |
ACCESSORY /HEATER BLOWER 2 | ORANGE (+) | IGNITION SWITCH HARNESS |
KEYSENSE | BLUE/ORANGE (-) | IGNITION SWITCH HARNESS |
PARKING LIGHTS ( - ) | BLUE/ORANGE (-) | @ HEADLIGHT SWITCH |
PARKING LIGHTS ( + ) | PINK/BLACK (+) and GREEN/ ORANGE (+) Use both, See NOTE *2 | @ BCM, 22-PIN PLUG, PINS 10 and 5, See DIAGRAM |
POWER LOCK | YELLOW or BLUE (TYPE F) See NOTE *3 | @ BCM, 12-PIN PLUG, PIN 8 or 3, See DIAGRAM |
POWER UNLOCK | Same wire, See DIAGRAM | See DIAGRAMS |
DOOR TRIGGER | YELLOW (-) | @ BCM, 22-PIN PLUG, PIN 11, See NOTE *1 |
DOMELIGHT SUPERVISION | YELLOW (-) | @ BCM, 8-PIN PLUG, PIN 8, See NOTE *1 |
TRUNK RELEASE | BLUE (+), Requires Part #775 Relay | IN DRIVERS KICK PANEL, HARNESS to REAR of VEHICLE |
SLIDING POWER DOOR | N/A | |
HORN | GREEN/ BLACK (-) | @ HORN SWITCH in STEERING COLUMN |
TACH | WHITE | IN PASSENGER KICK PANEL, 23-PIN PLUG, PIN 4 |
WAIT TO START LIGHT | N/A | |
BRAKE | WHITE (+) | @ SWITCH ABOVE BRAKE PEDAL |
FACTORY ALARM DISARM | DISARMS with a (-)Negative to the KEYSENSE wire | See KEYSENSE wire |
ANTI-THEFT | HYUNDAI'S TRANPONDER ANTI-THEFT SYSTEM, Canadian Vehicle ONLY!! | @ IGNITION SWITCH TUMBLER |
EXTRA INFORMATION |
NOTE *1 the BCM (Body Control Module), is part of the FUSE/RELAY BOX under the DRIVERS SIDE of the DASH. NOTE *2 this vehicle has 2 PARKING LIGHT wires, to connect will require 2 extra Relays Part #775, to Install, See DIAGRAM. NOTE *3 this vehicle uses a TYPE F Door Locking System that will require an extra Relay Part #775, to connect, See DIAGRAM. |
jared.malcolm
Member -
Posted: September 16, 2008 at 9:46 PM / IP Logged
Thursday, March 28, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
