2008 sprinter wiring?
desert366
Posted: September 22, 2008 at 12:20 PM / IP Logged
I'm looking for a diagram for a 2008 dodge sprinter. I'm going to be installing a marksman x11 into it. I found a diagram for an 06; but the body style has changed since then. Anyone know if it's the same or not?
desert366
Posted: September 22, 2008 at 1:54 PM / IP Logged
anybody?
Posted: September 22, 2008 at 2:00 PM / IP Logged
Only done the Mercedes Sprinter but it's the same vehicle. It's all CAN and you will need a CAN adaptor, contact Fortin or Idatalink.
StealthEs
Copper - Posts: 326
Posted: September 24, 2008 at 9:24 PM / IP Logged
looked it up the 06 according to Victory it is different then the 07-08
Cris
brhaugen
Copper - Posts: 275
Posted: September 25, 2008 at 7:30 AM / IP Logged
Got this from Audiovox....
   #513961: 2008 DODGE SPRINTER VAN WITH 3.0L TD ENGINE AND STANDARD AUDIO SYSTEM
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery RED / BLACK (+) RADIO HARNESS
Accesory BROWN & BROWN / RED (DATA) RADIO HARNESS
   THIS VEHICLE USES THE CAN DATA SYSTEM FOR ACCESSORY TURN ON
Ground BROWN (-) RADIO HARNESS
Illumination BROWN & BROWN / RED (DATA) RADIO HARNESS
Power Antenna YELLOW/BLACK (+) RADIO HARNESS
LF Speaker (+) BROWN / VIOLET
   THESE WIRES ALSO GO TO THE CENTER CHANNEL SPEAKER IF EQUIPPED
LF Speaker (-) BROWN / DARK GREEN
RF Speaker (+) BROWN / ORANGE
RF Speaker (-) BROWN / DARK BLUE
LR Speaker (+) BROWN / RED
LR Speaker (-) BROWN / WHITE
RR Speaker (+) BROWN / PINK
RR Speaker (-) BROWN / GRAY
Steering Cntrls NO
Speed Cntrl OPTIONAL
Radio Security YES
Security
Battery RED / GRAY (+) IGNITION SWITCH HARNESS
Ignition 1 BLACK (+) IGNITION SWITCH HARNESS
Starter 1 VIOLET (+) AT VEHICLE FUSE BOX
   NOT FOR REMOTE START, VEHICLE USES CAN DATA FOR STARTING
All Door Trigger
   USE INDIVIDUAL DOOR TRIGGERS AND DIODE ISOLATE EACH WIRE OR USE DOMELIGHT SUPERVISION
Domelight Super BROWN / DARK GREEN (-) AT BODY CONTROL MODULE
   BODY CONTROL MODULE IS LOCATED IN DRIVER KICKPANEL UNDER DASH
LF Latch DARK BLUE/DARK GREEN (-) AT DRIVER DOOR MODULE IN DRIVERS DOOR
RF Latch DARK BLUE/DARK GREEN (-) AT BODY CONTROL MODULE
   BODY CONTROL MODULE IS LOCATED IN DRIVER KICK PANEL UNDER DASH
LR Latch YELLOW/WHITE (-) AT BODY CONTROL MODULE
RR Latch PINK/WHITE (-) AT BODY CONTROL MODULE
Trunk Trigger DARK BLUE/DARK GREEN (-) AT BODY CONTROL MODULE
Hood Trigger BROWN / PINK (-) AT BODY CONTROL MODULE
Parking Lights GRAY/BLACK & GRAY/RED (+) AT BODY CONTROL MODULE
   THESE WIRES MUST BE DIODE ISOLATED.
Convenience
Headlights-Lo
LF Pk Lt Bulb GRAY/BLACK (+) AT FRONT LEFT PARKING LIGHT
RF Pk Lt Bulb GRAY/RED (+) AT FRONT RIGHT PARKING LIGHT
LR Pk Lt Bulb GRAY/BLACK (+) AT REAR LEFT PARKING LIGHT
RR Pk Lt Bulb GRAY/RED (+) AT REAR RIGHT PARKING LIGHT
All Hazrd Lights BLACK/ WHITE & BLACK/ ORANGE (+) AT VEHICLE HAZARD LIGHT SWITCH
LF Hazrd Bulb BLACK/ WHITE (+) AT FRONT LEFT DIRECTIONAL LIGHT
RF Hazrd Bulb BLACK/ ORANGE (+) AT FRONT RIGHT DIRECTIONAL LIGHT
LR Hazrd Bulb BLACK/ WHITE (+) AT REAR LEFT DIRECTIONAL LIGHT
RR Hazrd Bulb BLACK/ ORANGE (+) AT REAR RIGHT DIRECTIONAL LIGHT
Parking Brake BROWN / WHITE (-) AT BODY CONTROL MODULE
Remote Start
Ignition 2 BLACK/ ORANGE (+) IGNITION SWITCH HARNESS
Ignition 3 BLACK / YELLOW (+) IGNITION SWITCH HARNESS
Anti-Theft Type UNIVERSAL IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense WHITE/ RED (+) IGNITION SWITCH HARNESS
Speed Sense WHITE (AC) AT VEHICLE INSTRUMENT CLUSTER
Brake Lights BLACK/ RED (+) AT SWITCH ABOVE PEDAL
Reverse Lights BROWN / DARK GREEN (-) AT BODY CONTROL MODULE
Horn DARK GREEN (+) AT VEHICLE FUSE BOX
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock DARK BLUE/BLACK (REV) AT BODY CONTROL MODULE
   THESE ARE THE REAR AND SIDE DOOR MOTOR WIRES, YOU MUST USE ALL MOTOR WIRES AND USE REVERSE POLARITY FOR LOCK/UNLOCK
PowerLock DARK BLUE/BROWN (REV) AT BODY CONTROL MODULE
Driver Mtr Unlock DARK BLUE/RED (REV) AT DRIVER DOOR MODULE INSIDE DRIVER DOOR
Driver Mtr Lock DARK BLUE/BLACK (REV) AT DRIVER DOOR MODULE INSIDE DRIVER DOOR
Pas Mtr Unlock DARK BLUE/RED (REV) AT BODY CONTROL MODULE
Pas Mtr Lock DARK BLUE/BLACK (REV) AT BODY CONTROL MODULE
Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
Saturday, April 20, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
