2112 chevy sonic,factory remote 4 starter
TooDark
Copper - Posts: 163
Posted: November 02, 2012 at 7:31 AM / IP Logged
I use compustar starters and Im try to figure a way for the customer to use his factory remote for starting his car. Any ideas? Or is there a company that makes a add-on?
Platinum - Posts: 7,783
Posted: November 02, 2012 at 8:01 AM / IP Logged
With the CM6x00 series, here is some info.
CN3 Pin 14 Pink - Slave/Closed Loop negative (-) input. This is a dual-purpose optional input that can be
changed through Option 4-10.
Default: Slave/Timer Start (-) input. This is most commonly used when adding a remote start to a
factory keyless entry system. You can adjust the number of pulses with Option 2-04.
Optional: Closed Loop (-) input. This wire acts as an instant trigger when separated from ground (-).
It is most commonly used to protect headlights or trailers.
4-10 Trigger Start or Closed Loop System – Default setting sets the pink wire on CN3 as a trigger start
input, which will initiate remote start with a negative (-) trigger. Option 2-04 allows the number of
pulses required to initiate remote start to be changed. Setting 2 changes the wire to a closed loop
input, which makes it an instant alarm trigger when separated from ground - Ideal for protecting
trailers or headlights.
                 OPT 1     OPT 2
4-10 Trigger Start or Closed Loop Alarm Trigger Input      Trigger Start input      Closed Loop System  Input
2-04 Trigger Start – This option changes the number of times required for a negative (-) start input on the
pink wire of connector 3.
          OPT 1     OPT 2                OPT 3        OPT 4
2-04 Trigger Start       Off       Single Pulse     Double Pulse    Triple Pulse
Typically you connect to the drivers lock motor wire (+) and use a relay to convert to a (-) as the input for the
remote starter.  Set for 3 lock pulses and use the Factory Remotes.
Tuesday, April 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
