2004 F350 Viper 4706v remote start
ricerocketc
Posted: October 25, 2015 at 2:31 PM / IP Logged Link to Post Post Reply Quote ricerocketc
Looking to install a viper remote start in my 04 F350 diesel. It has a factory keyless entry with alarm and no chip key. After opening the dash I noticed that the "factory" alarm is actually a code system alarm model H63DB which also has the ability to be used as a remote start as well. Because the viper is 2way I'd like to still install it, my question is will I have to remove the code system alarm/starter or can I wire the viper to arm/disarm the code security system.
viper wiring guide
h63db main harness
h63db extended harness
Moderator - Posts: 12,488
Posted: October 25, 2015 at 9:05 PM / IP Logged Link to Post Post Reply Quote Velocity Motors
Use the DISARM input (+) BROWN wire to the status putput wire from the Viper and this will disable the alarm system for the Code Alarm.
Posted: October 26, 2015 at 1:18 AM / IP Logged Link to Post Post Reply Quote howie ll
Jeff you wrote disarm input (+) and connect to status output wire from Viper. But that goes to ground (-).
Regards, Howard.
ricerocketc
Posted: October 26, 2015 at 8:54 PM / IP Logged Link to Post Post Reply Quote ricerocketc
So am I to understand this solution won't work then?
ricerocketc
Posted: October 29, 2015 at 6:57 PM / IP Logged Link to Post Post Reply Quote ricerocketc
Anyone? I'd like to get this project going this weekend
Tuesday, April 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
