2016 Toyota Rav4, AutoStart 2383
daflipcyde
Copper - Posts: 68
Posted: November 10, 2016 at 10:39 PM / IP Logged Link to Post Post Reply Quote daflipcyde
I am installing Autostart 2383 with al ca d2d. Everything programmed well and and it started. Tested multiple times. I put all the panels back, tested it and it just cranks. Placed fob near ignition it starts. Checked all connections no cold solder. Tried reflashing al ca. It worked. Tried relearning al ca and it won't turn green. I don't know what I did but it does not want to learn anymore. Tried another module same thing. Key is H key. Turning key in ignition still works.
Also pink wire on al ca shows 12 volts when ignition is in on position.
I also tried hardwired with no luck.
Any ideas how to get this going?
racerjames76
Silver - Posts: 581
Posted: November 12, 2016 at 7:48 AM / IP Logged Link to Post Post Reply Quote racerjames76
When you tried reprogramming in vehicle did you do a hard reset? When reflashing it does not always reset the module.
Look for the hard reset procedure at the bottom of the guide.
Are you setting the ALCA for hardwire/DBI 1 flash or 2 flashes before turning the key on?
Sorry for the basic questions just have to cover the easy stuff.
If nothing there helps and you get to the steps of turning the key on what does the LED on the ALCA do. All of those flashes mean something. Take note of how many of what color flashes occur if any. Post back and I/we will try to help further!
-James
To master and control electricity is perfection. *evil laugh*
daflipcyde
Copper - Posts: 68
Posted: November 14, 2016 at 3:15 PM / IP Logged Link to Post Post Reply Quote daflipcyde
Ok I figured it out.
When I turned the key no LED lights would turn on. Tested pink wire at alca there was voltage. I unwrapped the tape from the harness and the pink wire came off the pin. I guess I taped it up too tight that it came off. Never happened before but i guess there's a first for everything.
Thursday, March 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
