2017 Dodge Ram ProMaster Alarm/Remote Start/Stereo Wiring
hr220a
Member - Posts: 13
Posted: March 09, 2017 at 5:51 PM / IP Logged
Can anyone provide me a alarm/ remote start wiring diagram for a 2017 Dodge Ram ProMaster? I can't seem to find the info anywhere. Thank you.
tonanzith
Gold - Posts: 593
Posted: June 25, 2017 at 12:56 AM / IP Logged
     DirectWire Vehicle Information
All Products
Item     Wire Color     Polarity     Wire Location
12 Volts     red/black (20A)     +     ignition switch, white 3 pin plug, pin 2
Second 12 Volts     red (70A)     +     BCM/dash fuse box, gray 2 pin plug, pin A
Starter     brown/white (gas); brown/gray (diesel)     +     ignition switch, white 3 pin plug, pin 3
Ignition     blue/red     +     ignition switch, white 4 pin plug, pin 2
Second Ignition     white/black     +     ignition switch, white 3 pin plug, pin 1
Accessory     blue     +     ignition switch, white 4 pin plug, pin 1
Keysense     lt. green (key lock)     +     key lock solenoid, white 2 pin plug, pin 2
CAN Bus High     lt. green (CAN C)     data     data link connector, black 16 pin plug, pin 6
CAN Bus Low     brown (CAN C)     data     data link connector, black 16 pin plug, pin 14
CAN Bus High 2     white (CAN B)     data     data link connector, black 16 pin plug, pin 9
CAN Bus Low 2     blue (CAN B)     data     data link connector, black 16 pin plug, pin 1
Power Lock     gray/brown (dash switch); blue/yellow (key switch)     -     BCM, rear, brown 60 pin plug (C8), pin 1; green 60 pin plg (C6), pin 53
For rear doors unlock, see trunk hatch/release.
Power Unlock     (same as power lock)     -1000 ohms
Lock Motor     orange/lt. green     5 wire     BCM/dash fuse box, black 32 pin plug (C5), pin 32
Driver Unlock Motor     white/black (front doors)     5 wire     BCM/dash fuse box, black 32 pin plug (C5), pin 18
Passenger Unlock Motor     red/black (rear sliding/cargo doors)     5 wire     BCM/dash fuse box, black 32 pin plug (C5), pin 14
Factory Alarm Arm     (arms on lock with door open)
Factory Alarm Disarm     (see disarm no unlock)
Disarm No Unlock     (transponder and ignition)
Parking Lights (+)     yel/gn (LF); yel/gy (RF); yel/gn (LR); yel/bu (RR)     +     BCM, blk 60 pin plug (C4), pins 55, 54; grn 60 pin plg (C6), pins 47,17
Parking Lights (-)     yellow/black     -     headlight switch, black 12 pin plug, pin 7
Hazards     purple/orange     -     BCM/dash fuse box, rear, brown 60 pin plug (C8), pin 55
Turn Signal (Left)     blue/white (F); blue/white (R)     +     BCM, black 60 pin plug (C4), pin 31; green 60 pin plug (C6), pin 19
Turn Signal (Right)     blue/black (F); blue/black (R)     +     BCM, black 60 pin plug (C4), pin 46; green 60 pin plug (C6), pin 18
Headlight     white/lt. green (high beam)     -     headlight switch, black 12 pin plug, pin 6
Reverse Light     white/lt. green     +     BCM/dash fuse box, green 60 pin plug (C6), pin 31
Left Front Door Trigger     white/purple     -     BCM/dash fuse box, green 60 pin plug (C6), pin 50
Right Front Door Trigger     white/black     -     BCM/dash fuse box, green 60 pin plug (C6), pin 51
Left Rear Door Trigger     (same as right rear door trigger)
Right Rear Door Trigger     black/purple     -     BCM/dash fuse box, green 60 pin plug (C6), pin 33
Dome Light     white/yellow     +     BCM/dash fuse box, green 60 pin plug (C6), pin 8
Trunk/Hatch Pin     white/blue (rear cargo doors)     -     BCM/dash fuse box, green 60 pin plug (C6), pin 35
Hood Pin     black/red     -     BCM/dash fuse box, black 60 pin plug (C4), pin 8
Trunk/Hatch Release     gray/white or white/gray (rear doors unlock)     -     BCM/dash fuse box, green 60 pin plug (C6), pin 27 or 41
Tachometer     blue/black (gas); white/yellow (diesel)     ac     camshaft position sensor, 4 pin plug, pin 1 or 2
Fuel Pump     gray     +     center console bhnd cup holders, 24 pin plg, pin 9
Rear Defroster     brown/blue     - latched     BCM/dash fuse box, green 60 pin plug (C6), pin 21
Mirror Defroster     yellow/black     - latched     BCM/dash fuse box, black 60 pin plug (C4), pin 19
Left Front Heated Seat     (switch is part of seat)
Right Front Heated Seat     (switch is part of seat)
Speed Sense     gray/white (3.6L only)     ac     PCM on driver side of engine, black 96 pin plug, pin 34
Brake Wire     lt. green/white     +     brake switch, white 4 pin plug, pin 4
Parking Brake     orange/white     -     BCM/dash fuse box, green 60 pin plug (C6), pin 44
Horn Trigger     brown/lt. green     -     BCM/dash fuse box, black 60 pin plug (C4), pin 51
Wipers     white/blue (LO); white/black (HI)     +     BCM/dash fuse box, black 60 pin plug (C4), pins 10, 4
Left Front Window (Up/Down)     red/black - black/red     A     BCM/dash fuse box, black 32 pin plug (C5), pins 1 - 2
Right Front Window (Up/Down)     red - black/purple     A     BCM/dash fuse box, black 32 pin plug (C5), pins 30 - 15
Radio 12V     red/yellow     +     radio, 16 pin plug, pin A4 or 52 pin plug, pin 44
Radio Ground     black     -     radio, 16 pin plug, pin A8 or 52 pin plug, pin 43
Radio Ignition     blue/lt. green (base); (CAN B on premium)     +     radio, 16 pin plug, pin A7
Radio Illumination     yellow/gray (base); (CAN B on premium)     dimmer     radio, 16 pin plug, pin A6
Left Front Speaker (+/-)     yellow - yellow/black     +,-     radio, 16 pin plug, pins B5 - B6 or 52 pin plug, pins 47 - 51
Right Front Speaker (+/-)     purple/orange - purple/black     +,-     radio, 16 pin plug, pins B3 - B4 or 52 pin plug, pins 46 - 50
Left Rear Speaker (+/-)     orange - orange/black     +,-     radio, 16 pin plug, pins B7 - B8 or 52 pin plug, pins 48 - 52
Right Rear Speaker (+/-)     lt. green - lt. green/black     +,-     radio, 16 pin plug, pins B1 - B2 or 52 pin plug, pins 45 - 49
Aux. Audio Input Left (+/-)     white - black     +,-     radio, 52 pin plug, pins 16 - 7
Aux. Audio Input Right (+/-)     lt. green - black     +,-     radio, 52 pin plug, pins 6 - 7
RSE Video (+/-)     red - white (rear view camera video)     +,-     radio, 52 pin plug, pins 31 - 32
Satellite Radio 12 Volts     (built into radio)
Item     Size     Depth     Location
Headunit     irregular          center of dash
Left Front Speaker     6.5          left front door
Left Front Tweeter               left front pillar
Right Front Speaker     6.5          right front door
Right Front Tweeter               right front pillar
Satellite Radio Tuner     (built into radio)
Gary Sather
Thursday, March 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
