new 2017/2018 remote starters
bogucki
Copper - Posts: 91
Posted: October 27, 2017 at 11:40 AM / IP Logged Link to Post Post Reply Quote bogucki
hey guys, im a professional installer and i was wondering on your guys opinions of the new starters out this year
the viper ds4 and ds4+
ads idatastart hc
and the new compustar FT-DC3-S
just wondering if you guys have used any of them yet and what your thoughts are?
i have used the idatstart and i love them i have had zero issues with them
and i heard the new FT-DC3-S is basically the same thing just under compustars name
i have also got a free viper ds4 from viper as a trial and its ok i did have issues programming it to my 2016 f-150 and had to call tech support and i could not get the bluetooth flashing to work. once i got it up and running it looks to be a good starter too
i really love that the bypass modules are build in such a time saver. and with all the T-harness they make a very easy clean install i can do the new chevys trucks, dodge rams and caravans in like 30 min start to end
boguckialex
Platinum - Posts: 7,783
Posted: October 27, 2017 at 7:10 PM / IP Logged Link to Post Post Reply Quote kreg357
I've used the iDatastart HC series and really like them. Very solid unit with great remotes. Never an issue.
I do not have any experience with DEI branded units so can't make any comparisons.
shark mobile
Copper - Posts: 83
Posted: November 11, 2017 at 8:50 PM / IP Logged Link to Post Post Reply Quote shark mobile
I used the hc1 Idatasrart and absolutely love it...cuts a lot of installs in half!!! DS4 is basically a dball2and it’s a preference thing. I prefers the simplicity of the programming of the Idata and for that reason it’s what I stock and use. BUT...Idata starts do not do manual transmissions (yet) and some brands that the DS4 will do...so having a few on the shelf is a good idea...don’t be a one trick pony, or you’ll get burned with a customers car in your shop that can’t be done and you look...dumb!
Best of luck
Solder, tape, repeat!
metz35
Copper - Posts: 458
Posted: November 15, 2017 at 4:11 PM / IP Logged Link to Post Post Reply Quote metz35
dc3 is a nice unit, accepts all T harnesses. but its a little pricey at around 91$ cost. plus remotes plus t harness if applicable. i try to stay under 100 in parts. its impossible with dc3
Tuesday, April 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
