F250-F350-F450 SUPER DUTY 2006-2007
KEY T-HARNESS IMMOBILIZER
FDKEY-4 N/A FORDS TRANSPONDER ANTI-THEFT SYSTEM, See NOTE #1
PART COLOR LOCATION DIAGRAM
12 VOLT CONSTANT YELLOW (+) and LIGHT GREEN/PURPLE (+) @ IGNITION SWITCH HARNESS
STARTER DARK GREEN (+) @ IGNITION SWITCH HARNESS
STARTER 2 N/A
IGNITION 1 RED/LIGHT GREEN (+) @ IGNITION SWITCH HARNESS
IGNITION 2 RED/BLACK (+) @ IGNITION SWITCH HARNESS
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 GRAY/YELLOW (+) @ IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 DARK/BLUE/LIGHT GREEN (+) @ IGNITION SWITCH HARNESS
KEYSENSE N/A
PARKING LIGHTS ( - ) N/A
PARKING LIGHTS ( + ) BROWN (+) @ HEADLIGHT Switch or VSM, GREEN Plug, Pin 2, See NOTE #2
POWER LOCK PINK/YELLOW (TYPE C), See NOTE #3 in DRIVERS KICK PANEL, @ DOOR HARNESS
POWER UNLOCK PINK/LIGHT GREEN (TYPE C), See NOTE #3 in DRIVERS KICK PANEL, @ DOOR HARNESS
LOCK MOTOR WIRE PINK/BLACK (5-WIRE TYPE) in DRIVERS KICK PANEL, @ DOOR HARNESS
DOOR TRIGGER Use DOMELIGHT Supervison wire
DOMELIGHT SUPERVISION BLACK/LIGHT BLUE (+) @ PASSENGER KICK PANEL or Cluster Blue Plug, Pin 26
TRUNK RELEASE N/A
SLIDING POWER DOOR N/A
HORN DARK BLUE (-) @ HORN SWITCH or VSM, GREEN Plug, Pin 6, See NOTE #2
TACH See NOTE #4
WAIT TO START LIGHT See NOTE #5
BRAKE LIGHT GREEN (+) @ SWITCH above BRAKE PEDAL
FACTORY ALARM DISARM N/A
ANTI-THEFT FORDS TRANSPONDER ANTI-THEFT SYSTEM, SEE NOTE #1 @ IGNITION SWITCH TUMBLER
NOTES
NOTE #1: This vehicle MAY BE equipped with a Special Anti-theft key, to remote start you will need a Bypass module 791,(use this module IF you have a extra ignition key to place inside the 791 to remote start, if you do not have an extra key to use or wish not to have a key placed inside this bypass module, a KEYLESS INTERFACE BYPASS MODULE that does not require a key to be placed inside the bypass module is Part # PKALL or PKFM, either one will work.
NOTE #2: The VSM (Vehicle Security Module) is located to the RIGHT of the GAS Pedal, just above the Transmission hump and below the Radio. the VSM is NOT Accessible from the Radio opening.
NOTE #3: Vehicles WITHOUT a FACTORY KEYLESS Entry Remote Control are a TYPE "C" Door Locking System. Vehicles WITH a FACTORY KEYLESS Entry Remote Control are a TYPE "B" Door Locking System and the LOCK wire is a WHITE/RED (TYPE B) and the UNLOCK is a BLACK/WHITE TYPE B), BOTH are located in the Drivers Kick Panel, at the Door Harness.
NOTE #4: On GAS Engines the TACH wire is any wire that is NOT: RED/LIGHT GREEN or RED/YELLOW (AC) at any IGNITION COIL or FUEL-INJECTOR. On DIESEL Engines the TACH wire is a LIGHT GREEN/WHITE (AC) wire in a 5-Pin Harness held up with WHITE tape located behind the Parking Brake Release.
NOTE #5: On this vehicle you can not use the WAIT TO START wire, you must use the WAIT TO START TIMER Programming in your Installation manual.
~wirewise~
