Connecting Lights To Relays
eeski11
Posted: July 28, 2018 at 3:24 PM / IP Logged Link to Post Post Reply Quote eeski11
I quickly drew up the lights i wanted to install and connect to two relays and be controlled with one switch. I want the lights to turn on with a switch. Would the way i drew it work correctly? I have the switch grounded and #86 going to the other. please let me know if that would work.
Connecting Lights To Relays - Last Post -- posted image.
the12volt
Administrator - Posts: 3,955
Posted: July 28, 2018 at 6:52 PM / IP Logged Link to Post Post Reply Quote the12volt
No, your diagram will do nothing as it is. You're supplying ground to both sides of the coil on both relays. Either change the input and output of your switch to 12V+ or change terminal 85 on both relays to 12V+. Also, I would fuse each relay separately with a smaller fuse instead of using one 50 amp fuse.
Connecting Lights To Relays - Last Post -- posted image. the12volt • Support the12volt.com
eeski11
Posted: July 29, 2018 at 9:18 AM / IP Logged Link to Post Post Reply Quote eeski11
That 50A fuse is coming from the battery. So i should use two fuses, one for each of the relays?
the12volt
Posted: July 29, 2018 at 10:00 AM / IP Logged Link to Post Post Reply Quote the12volt
Yes, preferably, or a single fuse rated at less than the current capacity of a single relay or the smallest wire's current capacity (whichever is lowest), but it may not be big enough for the total load. Again, I would fuse them separately. https://www.the12volt.com/wiring/recommended-car-stereo-wire-sizes.asp#current-draw-by-power
eeski11
Posted: July 29, 2018 at 2:52 PM / IP Logged Link to Post Post Reply Quote eeski11
Okay thanks for that info. I tried to correct my original post, its posted below. Is my contact at pin 87 and 30 suppose to be switched? Connecting Lights To Relays - Last Post -- posted image.
the12volt
Posted: July 29, 2018 at 2:59 PM / IP Logged Link to Post Post Reply Quote the12volt
Your diagram will work, but make sure you add the proper fuses.
eeski11
Posted: July 29, 2018 at 3:04 PM / IP Logged Link to Post Post Reply Quote eeski11
Thanks, i need to figure out how to properly do those calculations.
Thursday, April 18, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
