XL202, 2015 Nissan Rogue
ricardoboston
Copper - Posts: 268
Posted: November 15, 2018 at 7:25 AM / IP Logged Link to Post Post Reply Quote ricardoboston
hi there would anyone tell me what I need to buy to hook up a xl202 ,cause I have already the dball3 on 2015 Nissan rogue installed with works 3x lock but the range its suck besides the xl202 I know I need an antenna and remote but with antenna should I buy for it in order to work right thanks in advanced
sparkie
Platinum - Posts: 2,061
Posted: November 15, 2018 at 5:37 PM / IP Logged Link to Post Post Reply Quote sparkie
You need a RF kit which includes an antenna and the remotes. You will need to program the DB3 to work with the XL202 and program the XL202 to work with the specific remotes. There are various RF kits available.
sparky
ricardoboston
Copper - Posts: 268
Posted: November 15, 2018 at 6:24 PM / IP Logged Link to Post Post Reply Quote ricardoboston
sparkie thanks for help me I see so many RF KIT some for fortin some Compustar are they all fits on dball3?
sparkie
Posted: November 16, 2018 at 12:58 PM / IP Logged Link to Post Post Reply Quote sparkie
I've only used some DEI ones so I'm not sure about the others.
sparky
ricardoboston
Copper - Posts: 268
Posted: December 01, 2018 at 10:14 AM / IP Logged Link to Post Post Reply Quote ricardoboston
any tech knows how about range on XL 202 RFTD kit thanks
sparkie
Posted: December 02, 2018 at 2:23 PM / IP Logged Link to Post Post Reply Quote sparkie
The XL202 is only the receiver of the antenna signals and converts it to data to command the bypass module (DB3). The type of remote/antenna (RF kit) that plugs into the XL202 determines the range. If the RF kit is a 2 way unit, then they have more range than a 1 way system. Typical range for a 1 way is 500 - 1200 feet. A 2 way may give up to 2000 feet. Range will vary on a variety of factors. Battery strength, local interference or obstructions, window tint, etc.
sparky
ricardoboston
Copper - Posts: 268
Posted: December 04, 2018 at 7:18 PM / IP Logged Link to Post Post Reply Quote ricardoboston
sparkie that was a great explanation thanks a lot
Friday, April 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
