Toyota Like Auto-Headlight
eguru
Copper - Posts: 340
Posted: November 30, 2018 at 10:38 AM / IP Logged Link to Post Post Reply Quote eguru
If you would be satisfied with extending the headlight on time by only 4 minutes and 15 seconds, the PAC TR7 would work for you.
It would simplify the construction process.
https://pac-audio.com/catalog/specialty-items/tr7
geepherder
Platinum - Posts: 3,668
Posted: November 30, 2018 at 11:56 AM / IP Logged Link to Post Post Reply Quote geepherder
Eguru's solution is brilliant.
I do want to add if you use the transistor/relay setup, make sure to up the value of the bleed resistor to 10K ohms or more to minimize constant current draw when the car is off with the light switch on.
Wednesday, April 24, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
