Remote Start for 2016 Subaru Legacy Key Start ATM 4 Cylinders
wyciwug
Copper - Posts: 156
Posted: December 10, 2018 at 2:18 PM / IP Logged Link to Post Post Reply Quote wyciwug
I will be using Idatalink ADS AL, Python 4105P as the remote start. Will be using Data mode. I do have some questions.
What exactly is E-Brake status and do I have to connect that wire from the Bypass to Remote start? Which wire on the R.S. to be used for this?
The vehicle called for 2 starter wires but RS has only 1, I still need to use relay for the second starter, right? A friend/tech told me to use Diodes.
thanks
dcd
geepherder
Platinum - Posts: 3,668
Posted: December 10, 2018 at 3:01 PM / IP Logged Link to Post Post Reply Quote geepherder
E-brake status should be negative when the emergency brake is applied. On manuals you connect this to the neutral safety/e-brake input. On an automatic you can just ground it.
Search the wiring section. There are 2 second starter wires listed, both negative.
Your system may have a negative starter output, so double check. I agree, use diodes.
Platinum - Posts: 7,783
Posted: December 11, 2018 at 6:52 AM / IP Logged Link to Post Post Reply Quote kreg357
If you are using the ADS AL-CA bypass module and going D2D with the 4105, make sure you flash the module with the DBI AL(DL) SUB3 firmware.
I would follow the Type 4 Install diagram in the SUB3 install guide. The Strater2 wire shown is (+). Unfortunately, the 4105s Pink/White selectable wire can't be set to Starter, so I would use a relay to convert the 4105s Purple (-) Starter wire to the needed (+) signal. Using diodes to isolate a 25 amp and a 10 amp circuit may not be a good idea.
geepherder
Posted: December 11, 2018 at 7:13 AM / IP Logged Link to Post Post Reply Quote geepherder
Kreg is right. I just realized I was looking at the PTS in the wiring section, not key start. Diodes would be a bad idea.
wyciwug
Copper - Posts: 156
Posted: December 13, 2018 at 1:41 PM / IP Logged Link to Post Post Reply Quote wyciwug
Hello
I looked at the vehicle wiring diagram, I saw "Second starter RED (SS1); black (SS2) - push button ignition switch, black 14 pin plug, pin 7,2 < does this only avail in PTS, not Key start?
The 4105's Purple starter wire is (+)
dcd
Posted: December 13, 2018 at 5:24 PM / IP Logged Link to Post Post Reply Quote kreg357
Its possible you are making this more intriguing than it is. Flash the ADS AL-CA with the correct firmaware, download the install guide shown and follow the Type 4 install diagram.
The remote starter shown is generic so you will have to use the 4105 guide and programming to provide the needed outputs to complete the install.
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
