2014 Ford F-150 XLT, Aftermarket Amp
jas51384
Member - Posts: 32
Posted: April 03, 2019 at 11:38 AM / IP Logged Link to Post Post Reply Quote jas51384
I have a 2014 Ford F-150 XLT with the factory radio/sync/4.2" lcd. I'm trying to find a location to connect the remote turn on lead that doesn't have the accessory voltage retention. I've tried every "not used" fuse location in the passenger kick panel but since the accessory voltage relay is right in the middle of the fuse panel I'm assuming all those are going to retain voltage for the factory 10 minutes. If this is the only option will those 10 minutes have an impact on the battery when the radio isn't playing? I live in an area where then winters get cold and I don't want to kill the battery prematurely. Any info is welcome.
Thank you
John
geepherder
Platinum - Posts: 3,668
Posted: April 03, 2019 at 2:24 PM / IP Logged Link to Post Post Reply Quote geepherder
With the key off, don't the accessories lose power as soon as you open the door? If so, then you're not drawing power for an extra 10 minutes.
jas51384
Member - Posts: 32
Posted: April 03, 2019 at 3:12 PM / IP Logged Link to Post Post Reply Quote jas51384
The doors were open while I was testing and the radio shut off instantly when I turn the key off but did retain power. Maybe I need to have the doors shut and open them as part of the test. I guess I'll redo the tests.
jas51384
Member - Posts: 32
Posted: April 04, 2019 at 6:15 AM / IP Logged Link to Post Post Reply Quote jas51384
Well the "not used fuses" in the kick panel don't shut off when the door is opened or after 10 min or any short period of time. May have to go a different route.
geepherder
Posted: April 04, 2019 at 8:39 AM / IP Logged Link to Post Post Reply Quote geepherder
It sounds like those are constant power, not accessory. Why not check the ignition harness?
shark mobile
Copper - Posts: 83
Posted: April 04, 2019 at 9:17 PM / IP Logged Link to Post Post Reply Quote shark mobile
Violet/Green at the ignition harness...works like a charm...remember to solder
Solder, tape, repeat!
jas51384
Member - Posts: 32
Posted: April 07, 2019 at 8:12 AM / IP Logged Link to Post Post Reply Quote jas51384
Thank you both. I just tapped into the Accessory wire that the remote start was using. Plus I had to clean up the remote start mess. Whoever put that in didn't care where it all fell.
Tuesday, April 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
