Python 4106, 2010 Mazda 6
charger47
Member - Posts: 22
Posted: April 25, 2020 at 6:33 PM / IP Logged Link to Post Post Reply Quote charger47
Hi! Kind of new of this remote start anybody can help me for 2nd accessory on Mazda6 2010?
White 8-pin connector
1 RED/BLACK(+) FUSED 12V ACCESSORY/STARTER INPUT
2 PINK/BLACK(+) FLEX RELAY INPUT #87a key side (if required) of FLEX RELAY
3 PINK/WHITE(+) IGNITION 2/FLEX RELAY OUTPUT #30 of FLEX RELAY
4 RED(+) FUSED 12V IGNITION 1 INPUT
5 VIOLET(+) STARTER OUTPUT
6 ORANGE(+) ACCESSORY OUTPUT
7 RED/WHITE(+) FUSED 12V IGNITION 2 / FLEX RELAY INPUT #87
8 PINK(+) IGNITION 1 INPUT/OUTPUT
What is flex relay?
I really appreciate your help thanks.
Platinum - Posts: 7,781
Posted: April 26, 2020 at 5:51 AM / IP Logged Link to Post Post Reply Quote kreg357
The Flex Relay is a programmable ignition output. The Factory Default is IGN2 but you can change that to ACC2 or Starter2 via a programming change in Menu 3. So, yes you can use the Pink/White Flex Relay output to support your vehicles ACC2 need. Just make sure to power all three thick fused wires in that same harness. The Red/White is the supply for the Flex Relay output. Pink/Black would be unused for your application.
charger47
Member - Posts: 22
Posted: April 26, 2020 at 9:35 AM / IP Logged Link to Post Post Reply Quote charger47
Thanks i really appreciate your help
Thursday, March 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
