2011 Jeep Liberty, Remote Start Won’t Start
nitro7
Posted: May 02, 2020 at 11:31 AM / IP Logged Link to Post Post Reply Quote nitro7
I have a CMCHXA0 from idataLink as well as the T-Harness for my wife's 2011 Jeep Liberty. I have the T harness in place hood pin installed and tested for good ground. Went through the programming procedure and I received all of the proper led responses from the unit.
Try to start the vehicle and it will not start. I get the audible report from the horn as I should, but no start.
I do not however have RAP, horn output, or any of the lights wired in, I could care less about these things at this time.
I am probably leaving out some detail, but this is all I can think of.
Also is there a way to reset this unit to factory defaults?
Thank you
-Clint
nitro7
Posted: May 02, 2020 at 11:32 AM / IP Logged Link to Post Post Reply Quote nitro7
and to add, the vehicle has a normal key. I had another RS unit installed before with just a T harness and nothing else and it worked great until it didn't work anymore.
djdeito
Copper - Posts: 100
Posted: May 23, 2020 at 12:23 PM / IP Logged Link to Post Post Reply Quote djdeito
what firmware version did you install in the CMCHXA0 before doing the programming procedure?
Tuesday, April 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
