2006 Lexus RX400h, Audio Wiring
kraizter
Posted: June 10, 2020 at 9:28 AM / IP Logged Link to Post Post Reply Quote kraizter
Hello, anyone out there know which colors of wires go to the speakers in a 2006 Lexus RX4300h? I am trying to splice into the rear speakers for a powered kicker subwoofer and need to know which wires to splice into. Any help is greatly appreciated!! Thank you in advance :D
kraizter
Posted: June 10, 2020 at 10:33 AM / IP Logged Link to Post Post Reply Quote kraizter
Thank you for moving this post, did not know there was a more specific forum location. Also I meant 2006 Lexus RX400h
Platinum - Posts: 13,667
Posted: June 10, 2020 at 8:38 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Subwoofer (+/-)      violet - white (L), pink - blue/black (R) (front door woofers)      +,-      amplifier under rear cargo floor
Violet is positive, white negative on the left voice coil. Pink is positive and blue/black is negative on the right voice coil.
kraizter
Posted: June 12, 2020 at 7:43 AM / IP Logged Link to Post Post Reply Quote kraizter
Are you talking about the front speakers or the rear speakers? I cannot find the colored wires you have indicated. There are yellow and green wires going into the pigtail on the rear speakers in the doors. They each have yellow and green and it seems like one side yellow is positive and the other side yellow is negative.
However, when I tapped into the yellow and green wires coming in from the door there was no sound to a test speaker and the factory speaker in the door still functioned normally.
Also there are no green and yellow wires entering the drivers side cab from the speakers. They must change wire color inside the door.
kraizter
Posted: June 12, 2020 at 9:05 AM / IP Logged Link to Post Post Reply Quote kraizter
After reading this article I have moved to the factory amp.
https://www.clublexus.com/forums/rx-2nd-gen-2004-2009/396364-hooking-up-a-subwoofer-need-amp-wiring-diagram-for-rx400h-rx330-rx350.html
Here is a link to an image of what I'm currently working with off the factory amplifier.
https://ibb.co/b6CW7ZG
Which of these speaker wires would I be splicing into for the connection of a powered subwoofer?
Thank you again, this has been an ongoing project.
Posted: June 12, 2020 at 7:56 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Left Front Speaker (+/-)      brown - red/yellow or yellow - lt. green      +,-      amplifier under rear cargo floor
Right Front Speaker (+/-)      violet - pink      +,-      amplifier under rear cargo floor
Left Rear Speaker (+/-)      red - gray      +,-      amplifier under rear cargo floor
Right Rear Speaker (+/-)      red/yellow - blue      +,-      amplifier under rear cargo floor
Tuesday, April 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
