Compustar DC3 in 2016 Dodge Grand Caravan, Horn Wire
mizz3r0
Posted: August 26, 2020 at 3:51 AM / IP Logged Link to Post Post Reply Quote mizz3r0
looking for the horn wire for a 2016 grand caravan. installed compustar/firstech dc3, with t harness. horn still sounds when locking. but it shows i need to connect to grey/lt green wire in the 26pin green harness in the tipm.
wondering if the wire could also be connected under dash? if so, which wire. also if not, how can i disconnect said harness. been attempting last couple days to no avail. i find myself being the type that if its showing to connect....i need to or it eats at me.
mgoetz74
Silver - Posts: 424
Posted: August 27, 2020 at 1:49 PM / IP Logged Link to Post Post Reply Quote mgoetz74
you don't need to hook up the horn wire. The bypass module tells the factory security to arm/disarm and thats what is honking the horn. unless you want the panic to work from the compustar key fob.
mizz3r0
Posted: August 29, 2020 at 1:43 PM / IP Logged Link to Post Post Reply Quote mizz3r0
hi mgoetz, thanks for the response. in all honesty, I would leave it disconnected, but i am going to have this nagging at the back of my head with the wire being on the instructions and not connected. only reason I'm trying to get it done. watching video of the 2014 GC. but it does not show there. I will keep looking to see if i can get a reference for it. but no avail for an inside point yet.
mgoetz74
Silver - Posts: 424
Posted: August 29, 2020 at 2:06 PM / IP Logged Link to Post Post Reply Quote mgoetz74
if you really need it..
Horn Trigger     gray/lt. blue (1); gray/yellow (2) + TIPM/underhood fuse box, green 26 pin plug (C3), pins 24, 18
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
