2011 Ford Edge, Viper 5601 Keeps On Flashing Hazard Lights
charger47
Member - Posts: 22
Posted: November 01, 2020 at 3:01 PM / IP Logged Link to Post Post Reply Quote charger47
Hi there need some help, i install Viper 5601 alarm/remote starter i only install R/S on 2011 Ford Edge standard Key, working well but my problem hazard light keep on flashing sometime then and how turn-off led light on control center? and i got a type b door lock and how to wire straight to vehicle?
geepherder
Platinum - Posts: 3,668
Posted: November 01, 2020 at 6:32 PM / IP Logged Link to Post Post Reply Quote geepherder
If this only happens during remote start, it sounds like the parking light output is programmed to pulse (flash) instead of constant. Menu 3 item 12 option 2 (option 1 is constant during remote start, option 3 is off).
If the LED on the control center stays on, it's probably in valet mode. Cycle the ignition key on and off, then press the valet button once. You may need the door open, I don't remember. Alternatively, press f twice on the remote, then press unlock/disarm once.
Type B is negative switched. Since the Viper outputs are negative, you can simply connect them directly to the lock/unlock wires in your vehicle. Bulldog lists lock (Viper green) as blue/green in the driver's kick panel or the BCM gray 26-pin plug pin 6. Unlock (Viper blue) is listed as yellow/purple in the driver's kick panel or BCM gray 26-pin plug pin 8.
Friday, March 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
