2011 Dodge Nitro Heat With Infinity Wiring
jps501123
Posted: May 29, 2021 at 1:04 PM / IP Logged Link to Post Post Reply Quote jps501123
Would it be possible to get the schematics on them radios wiring harness colors? The wiring harness was cut too short so I’m redoing the pins inside the harness. I hope I’m commenting in the right spot I’m new at this.
Joshua Sullivan
jps501123
Posted: May 29, 2021 at 1:06 PM / IP Logged Link to Post Post Reply Quote jps501123
2011 Dodge Nitro Heat 4.0 V6 W/ Infinity and sub.
Joshua Sullivan
mgoetz74
Silver - Posts: 424
Posted: June 02, 2021 at 1:35 PM / IP Logged Link to Post Post Reply Quote mgoetz74
Radio 12V     yellow/red     +     radio, gray 22 pin plug, pin 1
Radio Ground     black/white     -     radio, gray 22 pin plug, pin 12
Radio Ignition     (CAN IHS BUS)
Radio Illumination     (CAN IHS BUS)
Factory Amp Turn-on     (CAN IHS BUS)
Power Antenna     gray/orange     +     radio, gray 22 pin plug, pin 7
Left Front Speaker (+/-)     gray/violet - gray/yellow     +,-     radio, gray 22 pin plug, pins 21 and 22
Note - Left Front Speaker (+/-): If equipped, the amplifier is in the right rear quarter panel. On vehicles with amplifier, the speaker wires are gray/purple - gray/yellow at the amplifier, black 16 pin plug, pins 8 and 16. The tweeter wires are gray/orange - gray/yellow at the amplifier, white 22 pin plug, pins 20 and 9.
Right Front Speaker (+/-)     dk. green/violet - dk. green/yellow     +,-     radio, gray 22 pin plug, pins 19 and 20
Note - Right Front Speaker (+/-): If equipped, the amplifier is in the right rear quarter panel. On vehicles with amplifier, the speaker wires are dk. green/purple - dk. green/yellow at the amplifier, black 16 pin plug, pins 7 and 15. The tweeter wires are gray/dk. green - gray/lt. green at the amplifier, white 22 pin plug, pins 19 and 8.
Left Rear Speaker (+/-)     gray/lt. green - gray/dk. green     +,-     radio, gray 22 pin plug, pins 8 and 9
Note - Left Rear Speaker (+/-): If equipped, the amplifier is in the right rear quarter panel. On vehicles with amplifier, the speaker and tweeter wires are gray/lt. green - gray/dk. green at the amplifier, black 16 pin plug, pins 13 and 5.
Right Rear Speaker (+/-)     dk. green/lt. green - dk. green/gray     +,-     radio, gray 22 pin plug, pins 10 and 11
Note - Right Rear Speaker (+/-): If equipped, the amplifier is in the right rear quarter panel. On vehicles with amplifier, the speaker and tweeter wires are dk. green/lt. green - dk. green/gray at the amplifier, black 16 pin plug, pins 4 and 12.
Subwoofer (+/-)     gry/brn - dk grn/brn (1); gry/wht - dk grn/wht (2)     +,-     amplifier in right rear quarter panel, black 16 pin plug, pins 14 and 6; 3 and 11
Tuesday, April 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
