2010 Volkswagen Polo, Alarm Wiring
smudger
Posted: June 10, 2021 at 5:50 AM / IP Logged Link to Post Post Reply Quote smudger
Does anyone have a tech wireing form for a Pol0 1.2 2010 to aid my instalation of aLB-100D-ST which has had me scratching my head for 4 days now
smudger
mgoetz74
Silver - Posts: 424
Posted: June 10, 2021 at 9:28 AM / IP Logged Link to Post Post Reply Quote mgoetz74
this is for a 2010 vw polo mark v, don't know if its the same since we don't have polos in us..
12 Volts     RED          AT IGNITION SWITCH
Starter     RED-BLACK          AT IGNITION SWITCH
Ignition     BLACK          AT IGNITION SWITCH
Power Lock     GREEN-YELLOW     NEG     AT DRIVERS DOOR HARNESS          Notes
Power Unlock     GREEN-YELLO     180ohm     SAME WIRE AS LOCK BUT WITH 180ohm RESISTOR
Turn Signal (Left)     WHITE-BLACK          SEE NOTES          Notes
Turn Signal (Right)     GREEN-BLACK
Left Front Door Trigger     BROWN-BLACK     NEG     AT LUME TO LIGHT BY FRONT WINDSCREEN, USE DIODE
Trunk/Hatch Pin     BLUE-RED          FOUND IN HARNESS BEHIND DRIVERS KICK, OR AT BOOT LIGHT
Hood Pin     FIT NEW
smudger
Posted: June 11, 2021 at 6:57 AM / IP Logged Link to Post Post Reply Quote smudger
Thanks for that I may just forget about the installation, just seems to be too complicated
smudger
Friday, April 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
