2012 Jeep Grand Cherokee, Remote Start Wiring
msebay01
Posted: September 26, 2021 at 2:16 PM / IP Logged Link to Post Post Reply Quote msebay01
Im doing a remote start install on my friends 2012 Jeep Grand Cherokee and i cant find wiring guides. Its a push to start. If anyone could help with this it would be greatly appreciated. Im installing a compustar with blade al and i cant find the ignition wiring. Thanks you
wirewise
Moderator - Posts: 489
Posted: September 26, 2021 at 5:15 PM / IP Logged Link to Post Post Reply Quote wirewise
Here's what I have for a 2012 Jeep Grand Cherokee.
GRAND CHEROKEE     2011-2013
KEY     T-HARNESS     IMMOBILIZER
N/A     N/A     CHRYSLER'S MULTIPLEX IGNITION/TRANSPONDER SYSTEM, SEE NOTE #1
PART     COLOR     LOCATION     DIAGRAM
12 VOLT CONSTANT     RED (+)     @ BATTERY or TIPM, See NOTE #2
STARTER     NOT USED FOR REMOTE STARTING!
STARTER 2     N/A
IGNITION 1     NOT USED FOR REMOTE STARTING!
IGNITION 2     N/A
IGNITION 3     N/A
ACCESSORY/HEATER BLOWER 1     N/A
ACCESSORY/HEATER BLOWER 2     N/A
KEYSENSE     N/A
PARKING LIGHTS ( - )     N/A
PARKING LIGHTS ( + )     WHITE/BROWN (+) (L) & WHITE/ORANGE (+) (R) MUST USE RELAY     @ HARNESS to REAR of vehicle, in DRIVERS KICK
POWER LOCK     PURPLE/LT.GREEN (-) THRU A 330 Ohm Resistor to LOCK     @ PASSENGER DOOR MODULE, BLACK 10-PIN PLUG, PIN 4
POWER UNLOCK     STRAIGHT (-) to UNLOCK
LOCK MOTOR WIRE     TAN/WHITE (5-WIRE TYPE)     @ DOOR HARNESS in DRIVERS KICK
DOOR TRIGGER     PURPLE (-)     @ DOOR HARNESS in DRIVERS KICK
DOMELIGHT SUPERVISION     YELLOW/WHITE (+)     @ HARNESS to REAR of vehicle, in DRIVERS KICK
TRUNK RELEASE     PURPLE (-)     @ HARNESS to REAR of vehicle, in DRIVERS KICK
SLIDING POWER DOOR     N/A
HORN     GRAY/YELLOW (+) and GRAY/LT.BLUE (+)     @ HORN SWITCH or GREEN 26-PIN PLUG(C3), PINS 18 and 24, See NOTE #2
TACH     Any wire NOT BROWN/WHITE (AC)     @ Any FUEL-INJECTOR
WAIT TO START LIGHT     N/A
BRAKE     WHITE/DK.GREEN (+)     @ BRAKE PEDAL SWITCH
FACTORY ALARM DISARM     N/A
ANTI-THEFT     CHRYSLER'S MULTIPLEX IGNITION/TRANSPONDER SYSTEM, SEE NOTE #1
NOTES
NOTE #1: This vehicle requires a special INTERFACE BYPASS MODULE for REMOTE STARTING PART # DBALL2 or XK09.
NOTE #2: The TIPM Module is located in the Engine compartment on the Passenger Fender.
~wirewise~ Verify all wiring with your meter before making any connections!
mgoetz74
Silver - Posts: 424
Posted: September 27, 2021 at 1:22 PM / IP Logged Link to Post Post Reply Quote mgoetz74
2012 grand Cherokee pts
http://images.idatalink.com/corporate/Content/Manuals/DL-CH4/COM-BLADE-AL(DL)-CH4-EN_20200320.pdf
very few wires get hooked up just follow guide and don't hook up anything not shown in the guide
Friday, March 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
