Can’t Program New Remote for Automate AM9, 2006 Chevrolet Silverado
tezz
Posted: October 22, 2021 at 11:49 AM / IP Logged Link to Post Post Reply Quote tezz
I purchased an 06 Silverado it has an AM9 with one LCD remote that has something loose inside so it keeps playing jingle bells throughout the day. I purchased a new remote but can't get the system into program mode. When I press the valet switch as directed it doesn't chirp. I thought the valet switch might be bad and put in a new one but that didn't help. If I can't get this unit to work is there a unit I can get that I just unhook the harnesses from the old unit and put into the new unit? Thanks
Platinum - Posts: 7,783
Posted: October 23, 2021 at 5:52 PM / IP Logged Link to Post Post Reply Quote kreg357
I can't find an Install Guide for the AM9 system to be sure but are you turning the ignition key to ON first?
tezz
Posted: October 23, 2021 at 6:39 PM / IP Logged Link to Post Post Reply Quote tezz
Yes, I turn the key on and press release, press and hold but do not get the confirmation chirp. I read if it was programed with a bit writer that it can only be reprogrammed with the bit writer, that may have been the case
Posted: October 24, 2021 at 6:29 AM / IP Logged Link to Post Post Reply Quote kreg357
That might be the case. Check in the AM9 program tables for settings that LOCKS making changes to program changes and remote pairing. That's the way it's done on some Viper systems.
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
