2014 Ram, Prostart TW3400, ADS ALCA Programming Issue
bruc007
Copper - Posts: 74
Posted: March 14, 2022 at 6:36 PM / IP Logged Link to Post Post Reply Quote bruc007
Hey . I am installing an older prosart tw3400 in a 2014 Ram Base Model. It is hardwired as well and no options to choose which bypass .   I am using an ADS ALCA bypass with CH8 ver 2.3 software.
All seems good, clone fine but upon activation the truck does everything but crank. The module when activated goes from green to solid red quickly. Any thoughts?
silvercivicsir
Copper - Posts: 402
Posted: March 15, 2022 at 9:40 AM / IP Logged Link to Post Post Reply Quote silvercivicsir
did you put the bypass in hardwire mode? two flash vs one flash, when programing? .. does the Tw3400 have a data port? it should from what i remember, and you can use dbi mode.
bruc007
Copper - Posts: 74
Posted: March 15, 2022 at 1:48 PM / IP Logged Link to Post Post Reply Quote bruc007
It is in hardwired mode. And it doesnt have a data port for the module. Also there is no settings to change protocols.
silvercivicsir
Copper - Posts: 402
Posted: March 15, 2022 at 9:27 PM / IP Logged Link to Post Post Reply Quote silvercivicsir
Do the door locks work? From the aftermarket fob?
hav007-roco
Member - Posts: 9
Posted: April 13, 2022 at 1:27 AM / IP Logged Link to Post Post Reply Quote hav007-roco
That unit requires tach to be hardwired directly. Also double check ground out when running. The units gwr may be burnt, ground directly for test. If u are getting red flashes on alca during start, chart says something to do with bypass incorrectly hooked up or programming.
Rocky Verma
Wednesday, April 24, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
