If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Tuesday, September 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
I'm just learning so would appreciate the help.
Thanks,
Under normal operation the vehicles Lock signal passes thru the relay, Pin 87A to Pin 30. With a aftermarket Lock signal output, the relay is energized. This opens the normal vehicle Pink Lock wire path through the relay and puts a (-) on the vehicles Lock wire going to the Fuse Box connector only.
