Viper 5305V With DB3, 2008 Chevrolet Express 3500
tmaguire648
Posted: June 25, 2026 at 12:49 PM / IP Logged Link to Post Post Reply Quote tmaguire648
I’m trying to install a Viper 5305V with a db3 module in my 2008 Chevy express 3500 van. the wiring diagrams I’m finding are all different. it appears most of the connections are made off the BCM in the passenger side of the dash. I was hoping someone had something better than what I’ve found online.
Tom maguire
zhangsheng
Posted: September 28, 2026 at 12:27 AM / IP Logged Link to Post Post Reply Quote zhangsheng
You're in the right neighborhood — on that generation of Express van most of the connections you need are indeed at the BCM on the passenger side. But don't trust wire colors from any diagram alone; meter every wire (12V constant, ignition, starter, lock/unlock) with a DMM before connecting anything. Diagrams vary because GM changed small things across model years, and a wrong assumption on the starter wire is an expensive mistake.
Once you've confirmed the wires: keep the 5305V/DB3 harness bundled tight and route it along the factory harness, secured to factory anchor points. Under the dash, wrap the sections that rest against the dash frame or HVAC ducts with PET fleece tape — the fuzzy fiber surface decouples the bundle from the panel so it doesn't buzz. It's better than PVC or plain cloth tape for this, and you only need it on the contact points, not the whole run.
And the unglamorous check that fixes most "new rattle after install" complaints: make sure every dash clip and panel fastener goes back intact. A missing or cracked clip lets the panel move, and no tape quiets that down. If the fleece tape you use carries a rated noise-damping class (LV 312 T1/T2 are the quiet grades), it'll also stay effective after years of heat instead of matting flat.
Where anything passes through the firewall, use a grommet — sheet metal will eventually saw through a wire that just rests on a bare hole.
Tuesday, October 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
