1999 Chevrolet Silverado, Viper 4806V Required Connections?
guig02
Posted: September 04, 2026 at 9:52 PM / IP Logged Link to Post Post Reply Quote guig02
Hey everyone,
I'm trying to get my Viper 4806V remote start installed in my 1999 Silverado 1500 (gmt800) and I've been trying to figure out what connections I need and what ones I don't. I have been trying to figure this out (on and off) for over a year now and every single time I just get confused and/or overwhelmed and/or frustrated.
I am planning to use the relay/resistor method to get around VATS so I don't think I need an additional module for that. Please correct me if I'm wrong. Do I need relays for this specific install (other than for VATS)? How many? Every time I try to figure this out I just want to cry lol, and I can't afford to have someone install it for me. Plus I'm stubborn. I WILL get this installed. I just need some help. I'm very comfortable working on my truck and with wiring things in general but for some reason this remote start is causing a mental block. If anyone could just tell me what I need to connect and where, I'd be forever indebted to you.
Anyway, here are the directions for installation that I can't seem to figure out.
Thank you!
lee.lopez
Copper - Posts: 334
Posted: September 04, 2026 at 10:34 PM / IP Logged Link to Post Post Reply Quote lee.lopez
Is it just the remote start portion where you're hung up, just the alarm, or both? Have you looked in the Vehicle Wiring tab at the top of the forum? Kreg posted a fairly in depth pictorial that should help you quite a bit.
guig02
Posted: September 05, 2026 at 4:24 PM / IP Logged Link to Post Post Reply Quote guig02
I guess I'm not even sure the answer to that. I had been viewing it as one install. Ideally I'd like to get as much functionality as possible. I actually created an account on here specifically to message Kreg with a question, but I am no longer using a bypass (at least I don't think I need to with my resistor+relay method) so the question I asked him doesn't apply anymore. I thought about sending him the above question, but ultimately decided to open it up to anyone. I also am wondering if these connections are the only ones I need for remote start function only? Thank you
lee.lopez
Copper - Posts: 334
Posted: September 05, 2026 at 5:00 PM / IP Logged Link to Post Post Reply Quote lee.lopez
Got it. You'll need to power 3 ignition wires, 2 can be powered directly with the Viper. A third will need a relay (triggered with the small pink/white). Accessory will need to be connected for the heat/AC. You'll need relays for the door locks to convert polarity. Another relay will be needed for your resistor bypass setup.
guig02
Posted: September 05, 2026 at 7:43 PM / IP Logged Link to Post Post Reply Quote guig02
Okay so are any of these right? I am 100% sure some (if not most) are wrong. This stuff hurts my head but I'm doing my best.
Main Harness, White 6-pin connector
1 RED (+)12V DC CONSTANT INPUT -- Red @ Ignition Switch harness
2 BLACK (-) CHASSIS GROUND -- GND
3 BROWN (-) 200mA HORN HONK OUTPUT --NOT USED
4 WHITE/BROWN PARKING LIGHT ISOLATION WIRE - #87a NORMALLY CLOSED of onboard relay -- NOT USED
5 WHITE PARKING LIGHT OUTPUT- #30 COMMON of onboard relay -- NOT USED
6 ORANGE (-) 500 mA (GWA) GROUND WHEN ARMED OUTPUT -- NOT USED
Remote Start, White 8-pin connector
1 RED/BLACK (+) FUSED 12V ACCESSORY/STARTER INPUT -- Yellow @ ignition Switch harness
2 PINK/BLACK (+) FLEX RELAY INPUT #87a key side (if required) of FLEX RELAY -- NOT USED
3 PINK/WHITE (+) IGNITION 2/FLEX RELAY OUTPUT #30 of FLEX RELAY -- Ignition 3 relay pin 30
4 RED (+) FUSED 12V IGNITION 1 INPUT -- Pink @ Ignition Switch harness
5 VIOLET (+) STARTER OUTPUT -- -- NOT USED
6 ORANGE (+) ACCESSORY OUTPUT -- Orange @ Ignition Switch harness
7 RED/WHITE (+) FUSED 12V IGNITION 2 / FLEX RELAY INPUT #87 -- White @ Ignition Switch harness
8 PINK (+) IGNITION 1 INPUT/OUTPUT -- Pink @ Ignition Switch harness
Door Lock, 3-pin connector
1 BLUE (-) 500mA UNLOCK OUTPUT -- Door unlock relay
2 EMPTY NOT USED
3 GREEN (-) 500mA LOCK OUTPUT -- Door lock relay
Auxiliary/Shutdown Harness, White 24-pin connector
1 PINK/WHITE (-) 200mA IGNITION 2/FLEX RELAY OUTPUT -- NOT USED
2 BLUE/WHITE (-) 200mA 2ND STATUS/REAR DEFOGGER OUTPUT -- NOT USED
3 RED/WHITE (-) 200mA TRUNK RELEASE OUTPUT -- NOT USED
4 BLACK/YELLOW (-) 200mA DOME LIGHT OUTPUT -- NOT USED
5 DARK BLUE (-) 200mA STATUS OUTPUT -- NOT USED
6 WHITE/BLACK (-) 200mA AUX 3 OUTPUT - -- NOT USED
7 WHITE/VIOLET (-) 200mA AUX 1 OUTPUT -- NOT USED
8 ORANGE/BLACK (-) 200mA AUX 4 OUTPUT --- NOT USED
9 GRAY (-) HOOD PIN INPUT (N/O or N/C) -- NOT USED (bought kit secondhand and wasn't included)
10 BLUE* (+) or (-) FACTORY HORN INPUT (Use Jumper to set polarity) -- *Set to negative* Black @ Steering Column
11 WHITE/BLUE ACTIVATION INPUT -- NOT USED
12 VIOLET/WHITE** TACHOMETER INPUT -- White @ Instrument Cluster
13 BLACK/WHITE*** (-) PARKING BRAKE/E-BRAKE INPUT -- GND (?)
14 GREEN/BLACK (-) 200mA FACTORY ALARM DISARM OUTPUT -- NOT USED
15 GREEN** (-) DOOR INPUT (N/O or N/C) -- Tan @ Passenger's Module
16 EMPTY ------------------------------------NOT USED
17 PINK (-) 200mA IGNITION 1 OUTPUT -- NOT USED
18 VIOLET** (+) DOOR INPUT -- NOT USED
19 VIOLET/BLACK (-) 200mA AUX 2 OUTPUT -- NOT USED
20 BROWN (+) BRAKE SHUTDOWN INPUT -- White @ Brake Switch
21 VIOLET/YELLOW (-) 200mA STARTER OUTPUT -- NOT USED
22 GRAY/BLACK (-) DIESEL WAIT TO START INPUT -- NOT USED
23 ORANGE (-) 200mA ACCESSORY OUTPUT -- NOT USED
24 GREEN/WHITE (-) 200mA FACTORY ALARM ARM OUTPUT -- NOT USED
lee.lopez
Copper - Posts: 334
Posted: September 06, 2026 at 6:19 AM / IP Logged Link to Post Post Reply Quote lee.lopez
Viper guides could definitely be more detailed as they can be confusing. I'm commenting on the wires that need changes, so if I don't mention that wire, you have it correct:
3 BROWN (-) 200mA HORN HONK OUTPUT - if you want the alarm to sound, connect this to the truck's negative horn wire (black)
5 WHITE PARKING LIGHT OUTPUT- #30 COMMON of onboard relay - if you want parking lights connect this to the truck's parking light wire (lt blue)
6 ORANGE (-) 500 mA (GWA) GROUND WHEN ARMED OUTPUT - this can be used if you want starter kill. Use this diagram: here
1 RED/BLACK (+) FUSED 12V ACCESSORY/STARTER INPUT - this, along with the other fused red wires in this harness will connect to a constant 12 volt source (battery power, not ignition). The red or red/white at the ignition harness will work.
3 PINK/WHITE (+) IGNITION 2/FLEX RELAY OUTPUT #30 of FLEX RELAY - this will connect to your ignition2 wire (white at the ignition harness)
4 RED (+) FUSED 12V IGNITION 1 INPUT - this connects to constant battery power (red or red/white at ignition harness)
5 VIOLET (+) STARTER OUTPUT - this will connect to your starter wire (yellow at ignition harness)
7 RED/WHITE (+) FUSED 12V IGNITION 2 / FLEX RELAY INPUT #87 - this connects to constant battery power (red or red/white at ignition harness)
1 BLUE (-) 500mA UNLOCK OUTPUT - if you want door lock control with the Viper, use a relay to convert polarity to positive:
here connect the relay's 12 volt output to the truck's white positive door unlock wire
3 GREEN (-) 500mA LOCK OUTPUT - if you want door lock control with the Viper, use a relay to convert polarity to positive:
here connect the relay's 12 volt output to the truck's lt blue positive door lock wire
1 PINK/WHITE (-) 200mA IGNITION 2/FLEX RELAY OUTPUT - use this to trigger a relay to power your truck's third ignition wire: here connect the relay's 12 volt output to the truck's brown at the ignition harness
10 BLUE* (+) or (-) FACTORY HORN INPUT (Use Jumper to set polarity) -- NOT USED this is an input, not an output. Horn will be controlled by the brown wire in the main harness
Hopefully this gets it going. Also be sure to program this for automatic transmission as the Viper default is manual. Post back with any follow up questions and we'll try to get them answered.
guig02
Posted: September 06, 2026 at 11:00 AM / IP Logged Link to Post Post Reply Quote guig02
Okay, thank you so much. That is exactly what I was looking for. I’ll try and carve the time out to get it installed sometime this week and I’ll report back. Again, thank you so much
guig02
Posted: September 06, 2026 at 1:39 PM / IP Logged Link to Post Post Reply Quote guig02
Okay just for my own sake, I wanted to rewrite this with all the correct connections. The first part should be all correct now. Is my relay wiring done correctly?
3 BROWN (-) 200mA HORN HONK OUTPUT -- Horn relay pin 85
5 WHITE PARKING LIGHT OUTPUT- #30 COMMON of onboard relay -- Lt blue @ Light Switch
6 ORANGE (-) 500 mA (GWA) GROUND WHEN ARMED OUTPUT -- Starter Kill relay pin 85
1 RED/BLACK (+) FUSED 12V ACCESSORY/STARTER INPUT -- Red or Red/White @ Ignition Switch harness
3 PINK/WHITE (+) IGNITION 2/FLEX RELAY OUTPUT #30 of FLEX RELAY -- White @ Ignition Switch harness
4 RED (+) FUSED 12V IGNITION 1 INPUT -- Red or Red/White @ Ignition Switch harness
5 VIOLET (+) STARTER OUTPUT -- Yellow @ Ignition Switch harness
7 RED/WHITE (+) FUSED 12V IGNITION 2 / FLEX RELAY INPUT #87 -- Red or Red/White @ Ignition Switch harness
1 BLUE (-) 500mA UNLOCK OUTPUT -- Door unlock relay pin 85
2 EMPTY NOT USED
3 GREEN (-) 500mA LOCK OUTPUT -- Door lock relay pin 85
1 PINK/WHITE (-) 200mA IGNITION 2/FLEX RELAY OUTPUT -- Ignition 3 relay pin 85
RELAYS
Starter Kill
30 -- Yellow @ Ignition Switch harness (cut this wire and connect it to 87a first and connect other half to 30??)
85 -- Viper Orange GWA Wire
86 -- 12v constant
87 -- NOT USED
87a -- Yellow @ Ignition Switch harness
Door lock/unlock (2 separate relays)
30 -- 12v constant
85 -- Viper Blue (unlock)/Green (lock)
86 -- Connect to wire @ pin 30
87 -- White (unlock)/Lt blue(Lock) @ Keyless Entry module
87a -- NOT USED
Ignition 3
30 -- 12v constant
85 -- Viper Pink/White
87 -- Brown @ Ignition Switch harness
87a -- NOT USED
lee.lopez
Copper - Posts: 334
Posted: September 06, 2026 at 2:53 PM / IP Logged Link to Post Post Reply Quote lee.lopez
RELAYS
Starter Kill
86 - connect this to ignition power (pink at ignition harness). That way it's not creating extra draw on the battery when armed. Otherwise if it sits a few days, the relay stays energized anytime it's armed, drawing down the battery.
Connect the purple Viper starter output to the vehicle side of the cut (not the key side). That way you can remote start while armed but it won't start with the key.
Other than that, looks good.
Sunday, October 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
