Two 2000 Chevrolet Silverados, Alarm, Remote Start
chapster1234
Posted: October 28, 2026 at 8:28 AM / IP Logged Link to Post Post Reply Quote chapster1234
I have two 2000 Silverado ls trucks.
One has the alarm activate when the door handle is pulled.
The second I want to get an alarm/start installed and the installer said that using dome light circuit won’t achieve this.
Can someone identify how to achieve this so I can pass on to installer. I feel he should know this?
zhangsheng
Member - Posts: 24
Posted: October 28, 2026 at 3:54 PM / IP Logged Link to Post Post Reply Quote zhangsheng
The working truck gives the clue. On these trucks the dome light comes on when the outside handle is lifted, because the switch in the door latch closes before the door actually opens. An alarm connected to dome light supervision reads that as a door opening and triggers. So the dome light method can work, but it has two weaknesses: pressing the dome override disables it completely, and the body computer dims and delays the dome light, which can make the trigger late or inconsistent. The reliable method is to skip the dome light and use the individual door trigger wires at the body control module instead. Each door latch switch sends a ground the moment the handle is lifted and the latch starts to move, before the door opens. Diode-isolate the driver and passenger door wires, with the bands facing the door side, and join them to the alarm's negative door trigger input. That gives an instant trigger when either handle is pulled, it still works with the dome override on, and it is not affected by dome light dimming. Before connecting anything, test it: meter each latch wire at the module, lift the outside handle, and the wire should switch to ground without the door opening. If a wire only grounds once the door is fully open, the latch switch in that door is worn, and no input wiring will cure it until the latch itself is sorted.
chapster1234
Posted: October 28, 2026 at 8:52 PM / IP Logged Link to Post Post Reply Quote chapster1234
Thank you so much for the detailed response. Makes total sense to me except for the truck I want it installed on when pulling door handle when locked, the dome light does not come on.
Am I still missing something?
Thanks again!
lee.lopez
Copper - Posts: 341
Posted: October 29, 2026 at 2:39 PM / IP Logged Link to Post Post Reply Quote lee.lopez
Can you manually turn on the dome light? Is the bulb possibly burned out?
Open all the doors and see if the light comes on. If it doesn't, press the button on the lower left of the dimmer switch. Did they come on? If so, close the doors and try them one at a time. If 3 doors cause the light to come on but 1 doesn't, that points to the door jamb switch. They should be interchangeable. Move sides/locations and see if the problem moves with the switch. If it does, buy a replacement.
chapster1234
Posted: October 29, 2026 at 7:18 PM / IP Logged Link to Post Post Reply Quote chapster1234
Truck is extended cab, two doors will turn on light when opening the door.
If doors are locked then pull handle (door staying closed) then dome light does not come on.
Other truck with alarm start with doors locked (door staying closed) and pulling door handle. The dome light comes on.
lee.lopez
Copper - Posts: 341
Posted: October 30, 2026 at 4:47 PM / IP Logged Link to Post Post Reply Quote lee.lopez
Ahh. I was looking at the diagram for the interior lights and it only shows mini wedge door jamb switches. Then I looked at the diagram for the BCM and it shows a door latch wire at B11.
You might try swapping door latch assemblies between the trucks and see if the issue follows the latch. Then try to lubricate it and work it back and forth with a screwdriver. If you can't get it to work, just order a replacement.
https://lemon-manuals.org.ua/Chevrolet/2000/Silverado%201500%2C%204D%20Pickup%20Extra%20Cab%2C%204.3%20W%2C%20RWD%2C%20Automatic/Repair%20and%20Diagnosis/Quick%20Lookups/Wiring%20Diagrams/System%20Wiring%20Diagrams%20-%201500/Interior%20Lights/
https://lemon-manuals.org.ua/Chevrolet/2000/Silverado%201500%2C%204D%20Pickup%20Extra%20Cab%2C%204.3%20W%2C%20RWD%2C%20Automatic/Repair%20and%20Diagnosis/Quick%20Lookups/Wiring%20Diagrams/System%20Wiring%20Diagrams%20-%201500/Body%20Control%20Modules/
Tuesday, November 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
