alarm iring diagram for 03 dodge caravan
Trinity
Member - Posts: 36
Posted: July 16, 2004 at 10:36 AM / IP Logged
where do i find or can anyone help with 03 dodge caravan wiring diagram. thanks
thepencil
Gold - Posts: 1,526
Posted: July 16, 2004 at 10:52 AM / IP Logged
Sources 1
DEI's info:| ITEM | WIRE COLOR |POL| WIRE LOCATION | | 12V|lt blue/red (10A) *1|+ |ignition harness | | STARTER|yellow |+ |ignition harness | | SECOND STARTER|PURPLE / brown *12 |- |ignition harness | | IGNITION|pink/white |+ |ignition harness | | ACCESSORY|*11 | | | | POWER LOCK|PURPLE / green *3 |- |conn. 3, pin 21 @ BCM *2 | | POWER UNLOCK|same wire | | | | LOCK MOTOR|tan/white | |conn. 2, pin 10 @ BCM *2 | | UNLOCK MOTOR|tan/lt. green | |conn. 2, pin 28 @ BCM *2 | | DISARM DEFEAT|tan/brown | |conn. 2, pin 26 @ BCM *2 | | PARKING LIGHTS +|DO NOT USE | | | | PARKING LIGHTS -|WHITE/ brown *8 | |headlight switch | | HEADLIGHTS|same wire | | | | DOOR TRIGGER|*4 |- |BCM *2 | | DOME SUPERVISION|use door trigger | | | | TRUNK/HATCH PIN|PURPLE / orange *9 |- |conn. 3, pin 29 @ BCM *2 | | HOOD PIN|PURPLE / lt. blue |- |conn. 3, pin 30 @ BCM *2 | |TRNK/HTCH RELEASE|*10 | |*10 | | FCTRY ALARM ARM|PURPLE / lt. blue |*5 |conn. 3, pin 14 @ BCM *2 | |FCTRY ALRM DISARM|same wire | | | | TACHOMETER|*6 | |ignition coil pack | | SPEED SENSE|blue/orange | |PCM *7 | | BRAKE WIRE|WHITE/ tan |+ |brake pedal switch | | HORN TRIGGER|GREEN/ purple |- |steering column | | WIPERS|brn/wht & brn/org |+ |wiper motor | | LF WINDOW UP/DN|org/lt grn - org/wht|A |drivers window switch | | RF WINDOW UP/DN|org/tan - org/gry |A |drivers kick panel | | LR WINDOW UP/DN|org/blu - org/lt blu|A |drivers kick panel | | RR WINDOW UP/DN|org/gry - org/grn |A |drivers kick panel | | RADIO 12V|gray/red |+ |radio | | RADIO GROUND| | | | | RADIO SWITCH|blue/pink |+ |radio | | RADIO ILLUMINATE|ORANGE / tan |+ |radio | | LF SPEAKER|green - grn/brn | |radio | | RF SPEAKER|gray - gray/brn | |radio | | LR SPEAKER|grn/blu - grn/org | |radio | | RR SPEAKER|gry/blu - gry/org | |radio |Notes:NOTE: Chrysler vehicles that use a gray ignition key have an immobilizer system that needs to be bypassed when remote starting. Use DEI part number 555C or 555U. *1 This wire is rated at 10 amps only. If installing any system with high current outputs, go to battery for 12v. *2 The BCM is in the drivers kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs. *3 Lock is negative trigger thru a 5.3K ohm resistor. Unlock is negative trigger thru a 2.0K ohm resistor. MUST use relays. *4 There are separate door triggers for each door, they are all in connector 3 at the BCM. The driver door trigger is purple in pin 6, the passenger door is PURPLE / white in pin 7, the left sliding door is PURPLE / gray in pin 8, and the right sliding door is purple / YELLOW in pin 5. Use all four and diode isolate each. See directfax document #1076 for wiring information. *5 Arm is negative trigger thru a 1.5K ohm resistor, this will also lock the doors. Disarm is negative trigger thru a 9.1K ohm resistor, if use double pulse this will also unlock the doors. MUST use relays. *6 On the 2.4L use blue/green or blue/tan. On the 3.3L/3.8L use blue/green, blue/tan or blue/orange. *7 The PCM is behind the driver side headlight. VSS is in the gray plug, pin 66. *8 The parking lights are negative trigger thru a 2.1K ohm resistor. The headlights are negative trigger thru a 790 ohm resistor. There is a rest resistance on the wire, so MUST use a relay to isolate away from the switch. See directfax document #1082 for wiring information. *9 A diode must be placed inline on this wire to avoid problems with the dome lights and parking lights. *10 Hatch release is PURPLE / tan in connector 2, pin 6 at the BCM. It is negative trigger thru a 1.69K ohm resistor. Left power sliding door is PURPLE / blue in connector 3, pin 1 at the BCM. It is negative trigger thru a 1.5K ohm resistor. Right power sliding door is the same wire as the left and it is negative trigger thru a 2.7K ohm resistor. Must use relays. *11 Accessory is not required for remote start. *12 The second starter wire is negative trigger thru a 180 ohm resistor. MUST use relay. Refer to directfax document #1083 for wiring information.
Sources 2
DODGE CARAVAN 2003 MINIVAN
Security Color Polarity Location
Battery
LIGHT BLUE / RED (+) IGNITION SWITCH HARNESS
Ignition 1
PINK/ WHITE (+) IGNITION SWITCH HARNESS
Starter 1
YELLOW (+) IGNITION SWITCH HARNESS
All Door Trigger
YELLOW/ ORANGE (+) AT BCM 25 OF BK/ GN
LF Latch
VIOLET (-) PIN 6 OF BLACK/ WHITE 34 PIN AT BCM
RF Latch
VIOLET/ WHITE (-) PIN 7 OF BLACK/ WHITE 34 PIN AT BCM
LR Latch
VIOLET/ GRAY (-) PIN 8 OF BLACK/ WHITE 34 PIN AT BCM
RR Latch
TAN/ ORANGE (-) PIN 5 OF BLACK/ WHITE 34 PIN AT BCM
Trunk Trigger
VIOLET/ ORANGE (-) PIN 29 OF BLACK/ WHITE 34 PIN AT BCM
Hood Trigger
VIOLET/ LIGHT BLUE (-) PIN 30 OF BLACK/ WHITE 34 PIN AT BCM
Alarm Disarm
VIOLET/ LIGHT BLUE (-) 1.5 K RESISTOR TO DISARM & UNLOCK -Note
MAY ALSO BE A 5.3K RESISTOR TO DISARM FACTORY ALARM.
Alarm Arm
VIOLET/ LIGHT BLUE (-) 2.0 K RESISTOR TO ARM & LOCK
Parking Lights
WHITE/ BROWN (-) @HDL SWTCH GRND, THROUGH 5.3K OHM RESISTOR -Note
OR 2.1 OHM RESISTOR
Remote Start
Battery
LIGHT BLUE/ RED (+) IGNITION SWITCH HARNESS
Ignition 1
Starter 1
Starter 2
VIOLET/ BROWN (-) IGNITION SWITCH HARNESS -Note
VIO/ BRN AT THE IGN WITH A 180 OHM RESISTOR -Note
MUST USE RELAY TO ENHANCE GROUND, DURING CRANK ONLY, WITH 180 OHM RESISTOR. IF YOU DO NOT HAVE 4 PIN AUXILARY HARNESS, ATTACH LT. BLUE IGNITION 3 TO 85, TAP OFF OF START WIRE TO 86, GROUND THE 180 OHM RESISTOR AND ATTACH TO 87, CUT THE VIOLET/ BROWN
Key Sense
LIGHT BLUE (-) IGNITION SWITCH HARNESS
Tachometer
DARK BLUE/ GREEN (AC) PIN 11 AT PCM LFT CORNER OF ENGINE COMP.
Crankshaft Sensor
BROWN / LIGHT BLUE (-) PIN 32 OF PCM LFT CORNER OF ENGINE COMP.
Camshaft Sensor
BLUE/ GRAY (-) PIN 33 OF PCM LFT CORNER OF ENGINE COMP.
Speed Sense
DARK BLUE/ ORANGE (AC) 66 OF PCM LFT CORNER OF ENG. COMP. 2ND PLG
Parking Lights
OR 2.1 OHM RESISTOR
Brake Lights
WHITE/ TAN (+) AT BRAKE LIGHT SWITCH
Reverse Lights
WHITE/ LIGHT GREEN (+) PIN 9 OF BLACK/ GREEN 34 PIN AT BCM
Horn
DARK GREEN/ VIOLET (-) STEERING COLUMN HARNESS
Doorlocks/ Windows
Power Unlock
VIOLET/ DARK GREEN (-) PIN 21 AT BCM 2.0K -Note
USE 2KOHM RESISTOR TO UNLOCK THE DOORS VIOLET/ BLUE -DR. SIDE SLIDER USES A 4.7 OHM RESISTOR TO OPEN & CLOSE (NEG PULSE)
VIOLET/ BLUE -PASS. SIDE SLIDER USES A 1.2 OHM RESISTOR TO OPEN & CLOSE (NEG PULSE)
PowerLock
VIOLET/ DARK GREEN (-) PIN 21 AT BCM 5.3K -Note
USE 5.6KOHM RESISTOR TO LOCK THE DOORS VIOLET/ BLUE -DR. SIDE SLIDER USES A 4.7 OHM RESISTOR TO OPEN & CLOSE (NEG PULSE)
Driver Mtr Unlock
TAN/ LIGHT GREEN (REV) PIN 28 OF BLACK/ GREEN 34 PIN AT BCM
Driver Mtr Lock
TAN/ WHITE (REV) PIN 10 OF BLACK/ GREEN 34 PIN AT BCM
Pas Mtr Unlock
TAN/ BROWN (REV) PIN 26 OF BLACK/ GREEN 34 PIN AT BCM
LF Window Up
ORANGE / LIGHT GREEN (+)
LF Window Dn
ORANGE / WHITE (+) AT DRIVERS SWITCH
RF Window Up
ORANGE / TAN (+) AT DRIVERS SWITCH
RF Window Dn
ORANGE / DARK GREEN (+) AT DRIVERS SWITCH
LR Window Up
ORANGE / DARK BLUE (+) AT DRIVERS SWITCH
LR Window Dn
ORANGE / LIGHT BLUE (+) AT DRIVERS SWITCH
RR Window Up
ORANGE / GRAY (+) AT DRIVERS SWITCH
RR Window Dn
GRAY/ DARK GREEN (+) AT DRIVERS SWITCH
Convenience Color Polarity Location
LF Pk Lt Bulb
WHITE/ BROWN (+)
RF Pk Lt Bulb
(+) WHITE/ ORANGE
LR Pk Lt Bulb
WHITE/ BROWN (+)
RR Pk Lt Bulb
WHITE/ ORANGE (+)
LF Hazrd Bulb
WHITE/ LIGHT GREEN (+) PIN 1 OF BLACK/ GREEN 34 PIN AT BCM
RF Hazrd Bulb
WHITE/ TAN (+) PIN 3 OF BLACK/ GREEN 34 PIN AT BCM
LR Hazrd Bulb
WHITE/ DRK. GREEN (+) PIN 2 OF BLACK/ GREEN 34 AT BCM
RR Hazrd Bulb
WHITE/ BROWN (+) PIN 4 OF BLACK/ GREEN 34 AT BCM
Wipers-Lo
BROWN / WHITE (+) AT WIPER MOTOR
Trnk Release
VIOLET/ TAN (-) PIN 6 OF PLUG 2 AT BCM USE 1.69K RESISTOR -Note
BCM -BODY CONTROL MODULE IS IN THE DRIVERS KICK NEAR THE PARKING BRAKE
Be careful whose advice you buy, but be patient with those who supply it.alarm iring diagram for 03 dodge caravan - Last Post -- posted image.
Saturday, April 20, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
