96 gmc safari alarm/starter wiring diagra
awsomedude
Copper - Posts: 50
Posted: January 21, 2005 at 8:01 PM / IP Logged
I need an alarm starter wiring diagram for a 1996 gmc safari
KarTuneMan
Platinum - Posts: 7,056
Posted: January 22, 2005 at 8:45 AM / IP Logged
jandjav
Member - Posts: 13
Posted: February 05, 2005 at 12:37 AM / IP Logged
PRINTABLE VERSION
GMC
MODEL YEAR(S)
SAFARI 1996 -1997
KEY T-HARNESS IMMOBILIZER
N/A GM-1 N/A
PART COLOR LOCATION DIAGRAM
12 VOLT CONSTANT RED (X2) IGNITION SWITCH HARNESS
STARTERYELLOW (+) IGNITION SWITCH HARNESS
STARTER 2N/A
IGNITION 1PINK (+)IGNITION SWITCH HARNESS
IGNITION 2PINK/WHITE (+) See NOTE *IGNITION SWITCH HARNESS
IGNITION 3N/A
ACCESSORY /HEATER BLOWER 1ORANGE (+) IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2N/A
KEYSENSEN/A
PARKING LIGHTS ( - )N/A
PARKING LIGHTS ( + )BROWN (+) @ HEADLIGHT SWITCH
POWER LOCKLIGHT BLUE RELAYS IN PASSENGERS KICK (TYPE A)
POWER UNLOCKWHITE RELAYS IN PASSENGERS KICK (TYPE A)
DOOR TRIGGERPURPLE (-) @ HEADLIGHT SWITCH
DOMELIGHT SUPERVISIONUSE DOOR TRIGGER
TRUNK RELEASEGREEN (-) @ HATCH RELEASE SWITCH
SLIDING POWER DOORN/A
HORNBLACK (-) @ STEERING COLUMN HARNESS
TACHWHITE @ ECM See NOTE **
WAIT TO START LIGHTN/A
BRAKEWHITE (+) SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM N/A
ANTI-THEFTN/A
EXTRA INFORMATION
NOTE * the 1997 may have a WHITE (+) for the IGNITION #2 wire. NOTE ** The ECM is located on the DRIVERS SIDE of ENGINE COMPARTMENT, behind the battery, the tach wire will be in a BLACK Plug labled WHITE.
LINK 1 LINK TEXT 1 LINK 2 LINK TEXT 2
Tuesday, January 18, 2022 • Copyright © 1999-2022 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
