How do i fit 18’s on my civic?
KarTuneMan
Platinum - Posts: 7,056
Posted: July 31, 2006 at 12:01 PM / IP Logged
http://www.lesschwab.com/wheels/plussizing.asp Look at the wheel and tire sizes here.....from a 14 to an 18, and gained less than 1/4 inch. From where the wheel mounts to the car, thats 1/8 inch on top and 1/8 inch on the bottom. Thats acceptable in a +4. You have gained OVER 1.5 inches. That not gonna work. Speedo, milage, AND the actual miles on the OD. It's gonna get lousy milage, your gonna be goin 8% faster than the speedo shows, and you'll put more miles on it than you have actually traveled....not to mention, put a couple of your buddies in the car and go for a drive. The choice is ultimately yours, but I have provided you with enough information to help you see......it's the wrong choice. Your fenders are gonna look terrible with all those wrinkles in them too. You need a 215/35/18 to even come close to a proper fitment.
Moderator - Posts: 12,488
Posted: August 01, 2006 at 8:44 AM / IP Logged
Did you lower the vehicle at all & how much ?
ridin4jesus
Member - Posts: 32
Posted: August 01, 2006 at 10:55 AM / IP Logged
nope havent touched the suspension at all, all factory
ridin4jesus
Member - Posts: 32
Posted: August 02, 2006 at 12:28 PM / IP Logged
also if i used coil overs, can anyone give me some good brands(names, things to look out for, etc.), there are way too many out there. thanks guys
Posted: August 03, 2006 at 9:18 AM / IP Logged
I've modified alot of Civic's in the past and knowing the way they are set up....... yours must look like a Tonka Truck ! If you haven't lowered the car yet, you WILL have issues with the tires rubbing once you lower the vehicle.
Respectable coilover brands are Skunk2, Eibach, Ground Control & Tein. Any one of these are great companies to go with but expensive.
ridin4jesus
Member - Posts: 32
Posted: August 03, 2006 at 11:12 AM / IP Logged
thanks, do you know of a way i can raise the civic, im not trying to lower it
KarTuneMan
Posted: August 03, 2006 at 11:22 AM / IP Logged
My friend....these tires and wheels are the wrong size.....lift and lower all you want. They still are the wrong size.
austincustoms
Copper - Posts: 232
Posted: August 06, 2006 at 12:06 AM / IP Logged
Since this probably already looks rediculous, have you tried the old baseball bat trick?  take a wooden bat, put it on the tire and roll the car foward, letting the bat roll the fenders out.
civicdetailer
Copper - Posts: 51
Posted: August 06, 2006 at 6:48 AM / IP Logged
get the right size wheel and tire combo. a 235/40 is nowhere even close to fitting on a civic.... and raising it would just look absolutely rediculous... more so than how it probably looks now with 18's and stock ride height. how wide are these rims and what offset??
Nitrous is like a hot girl with an STD. You know you want to hit it, but you are scared of the consequences.
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
