subs, ohm loads, resistors?
krewltee
Posted: October 08, 2006 at 4:50 PM / IP Logged
im often viewing the forums on " the down low" but today i must ask for helpsubs, ohm loads, resistors? - Last Post -- posted image.////////ok now my delema ..............i have 4 subs dvc 4 ohms per coil .....i normally run a single mono amp @ 2 ohm on the 4 subs but reccently blew it up ,now i put a kicker 2 channnel amp that wont hold 2 ohms bridged......if i recall correctly someone once said could drop the loads with the use of resistors / if so can someone please enlighten me!
krewl intentions c.c
rochester n.y
cloak559
Copper - Posts: 215
Posted: October 08, 2006 at 5:05 PM / IP Logged
Either wire it at 8ohms, or buy a new amp....
'89 Mercedes-Benz 300E
Pioneer DEH-5900UB
(2)RE Audio SX 10"s
(1)US Amps MD3D
3ft^3 @ 37Hz
Blowing up in a car accident doesnt worry me, as long as I'm putting out some major dB's when I die...
krewltee
Posted: October 08, 2006 at 5:39 PM / IP Logged
thanx but  thats no help!subs, ohm loads, resistors? - Last Post -- posted image.
rochester n.y
cloak559
Copper - Posts: 215
Posted: October 08, 2006 at 5:49 PM / IP Logged
Basically, I was saying that you cannot use resistors to change the ohm load. The resistor would be consuming power from your amp, so you would only get about 1/2 the power to your subs...
Like I said... 8ohms, or new amp...subs, ohm loads, resistors? - Last Post -- posted image.
Pioneer DEH-5900UB
(2)RE Audio SX 10"s
(1)US Amps MD3D
3ft^3 @ 37Hz
krewltee
Posted: October 08, 2006 at 5:59 PM / IP Logged
i think ill try 1 ohm per chhannl and see how long before the amp fryssubs, ohm loads, resistors? - Last Post -- posted image. thanx homie
rochester n.y
aznboi3644
Gold - Posts: 2,600
Posted: October 08, 2006 at 6:15 PM / IP Logged
How about instead of frying that amp you sell it and buy a new mono amp
Monday, August 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
